Interesting idea. I would have thought that the original higher place waste gate pipes would have been better for that approach than placing them lower. Lower pipes might help the diffuser, perhaps, especially if they are also trying to blow the waste gate in braking.ryaan2904 wrote: ↑17 Nov 2020, 20:08I think motorsport Italy analysed this. They said that this whole wastegate upgrade is a bid to improve stability in slow corners/hard breaking. The idea is to improve the flow under the rear wing area to aid both the diffuser and the rear wing. The rear wing because high flow/speed just underneath the rear wing will cause high pressure on the flatter/lower part of the wing and thus increase efficient downforce.Just_a_fan wrote: ↑17 Nov 2020, 19:50Isn't the position of the waste gate pipes more just about freeing the exit for the cooling outlet around the exhaust? By sticking it alongside the crash structure, it's in an area of poor flow anyway so likely has less impact on the cooling package. Also, the race was cold so they probably banked on being able to run a tighter engine cover as cooling would also be less of an issue in the first place.godlameroso wrote: ↑17 Nov 2020, 16:32
The front wing lowest element has been made bigger, and there's a bigger curve where the element meets the 250 section. The mouth of the cape is bigger, no doubt to capture more airflow.
Looks like they're using their "T" wing and rear upper A arm in a clever way with their wastegate pipes.
Engine cover has improved, looks tighter.
I'd be interested to hear how you think they might be interacting the waste gate pipes with the t-wing/suspension arm.
The major goal is to prevent stalling of air in low speeds to aid slow cornering.
Also said the gold paint sort of thing on the exhaust is a heat resistant to aid in all this. Dunno how tho
Is this a clever loop hole that they've found, I wonder.
