Ferrari SF21
basti313
basti313
Re: Ferrari SF21
Sevach wrote:
11 Mar 2021, 04:14
11 Mar 2021, 00:47
I dont know about you guys, but I'm liking how the car looks. If all works out it will be fighting for podiums, which is no mean feat this year with two solid RedBulls.
In a year where most teams are presenting cars that look very close to last season models, Ferrari succeeded in making this look a lot more advanced than what they had before.
Still, the proof needs to be on the racetrack.
Absolutely. But in my point of view very logical:
- More power, so add more small winglets. Most probably last year solution, but too draggy.
- Guide a bit more air to the floor and rear brake ducts to gain back the loss of the rule change. The nose is a bit of a Alfa solution.
- Correct the bad rear axle, maybe already with some view on 2022.
- Change packing and cooling with view on 2022.
So the big change is maybe just based on the errors from last year and prep for next year.
Don`t russel the hamster!
Re: Ferrari SF21
Dunno what Mark Hughes is talking about. The lower 2021 wishbones look conventional and similar to 2020...
Stu
Re: Ferrari SF21
f1rules wrote:
10 Mar 2021, 15:40
interesing cape
https://pbs.twimg.com/media/EwH0e5cXYAc ... name=small
Just what I was thinking!
I wonder...
Are they feeding the S-duct with the two smaller (outer) openings, but feeding the cape with the central openings? This is very different to the J-vane design from previous years and the two outer openings do not look to have enough capacity to ‘drive’ the cape. The ducting from them (visible just behind them) suggests that air is being ducted upwards from these.
Re: Ferrari SF21
Zynerji wrote:
11 Mar 2021, 03:55
Can we call this nose the "Viper" nose?
Pretty please?
Yes, I like that. =D>
Giando
93
Re: Ferrari SF21
The relatively new nose cone reminded me two things seen in the past, although i know the similarity are purely aesthetics and not technical in terms of concept and airflow impact.
At first, the 'duck' nose of the Ferrari 639/640 and its 'divergent' shape
And then, the latest evolution of the Catheram
Stu
Re: Ferrari SF21
I know that they are only studio shots, but I’m fairly certain that the rake has been reduced compared to last year, it will be interesting to see if it has been and whether they have extended the wheel-base as well. A lot of interesting details on this launch!!
bucker
bucker
Re: Ferrari SF21
cplchanb wrote:
10 Mar 2021, 15:55
How can they not use any tokens for the nose??? It's been modified quite heavily similar to alfa Romeo.
Tokens are for non aero surfaces.
Giando
93
Re: Ferrari SF21
bucker wrote:
11 Mar 2021, 10:16
cplchanb wrote:
10 Mar 2021, 15:55
So, the actual crashbox hadn't been modified at all and there's bodywork around it, which is what we see from the outside, right? sort of a double layer
jjn9128
779
Re: Ferrari SF21
Giando wrote:
11 Mar 2021, 10:22
bucker wrote:
11 Mar 2021, 10:16
cplchanb wrote:
10 Mar 2021, 15:55
Correct.
#aerogandalf
Re: Ferrari SF21
Re: Ferrari SF21
On track for the first time
Via @ASJesusBalseiro
Re: Ferrari SF21
Video comparison by Salvatore Asero #SF21 newsf1.it
wowgr8
wowgr8
29
Re: Ferrari SF21
Morteza wrote:
11 Mar 2021, 12:22
https://pbs.twimg.com/media/EwLjkXnWgAQ ... name=large
Considering everyone's at Bahrain how is it that there aren't more pictures of the car? Just one. Or is it that when Ferrari rent the track for the filming day the other teams and all other personnel have to clear out for that time period?
Re: Ferrari SF21
wowgr8 wrote:
11 Mar 2021, 13:03
Morteza wrote:
11 Mar 2021, 12:22
I found this
wogx
60
Re: Ferrari SF21
