Is it better to align the T-cams or the lights/diffusers in your opinion?
![Image](https://i.imgur.com/AurEiFC.jpg)
2021RB rear-end vs 2019 RB rear-end (2021 AT02)
![Image](https://i.imgur.com/NwqHTyN.jpg)
Wait does the McLaren have brake duct winglets below the step plane?Blackout wrote: ↑16 Mar 2021, 12:00A521 Vs MCL35M
Yes. The brake ducts/winglets are defined relative to the wheel hub not the reference plane.SiLo wrote: ↑17 Mar 2021, 17:39Wait does the McLaren have brake duct winglets below the step plane?Blackout wrote: ↑16 Mar 2021, 12:00A521 Vs MCL35M
Perhaps RB felt it was worth the compromise of having the pullrod in the way by moving the suspension mounting down low allowing a more aggressive undercut at the rear of the car.
I was about to post the same. RB perhaps make up for it with the narrower gearbox casing.godlameroso wrote: ↑18 Mar 2021, 19:02Perhaps RB felt it was worth the compromise of having the pullrod in the way by moving the suspension mounting down low allowing a more aggressive undercut at the rear of the car.
The length of the pushrod doesn’t matter, the angle does. Both RedBull and McLaren have their pushrod so far away from the actual motion (by being swept forward) that there will be difficulty to have the same level as precision as a pushrod that is more in line with the axle.godlameroso wrote: ↑18 Mar 2021, 18:59Would mounting the pushrod higher make it shorter and thus lower motion ratios giving you a smaller tuning window? In McLaren and RBR's case they have very long pushrods and large motion ratios giving them more fine tuning control over damping and spring rates.
