Ferrari SF21
f1316
f1316
82
Re: Ferrari SF21
ing. wrote:
15 Apr 2021, 17:54
wowgr8 wrote:
15 Apr 2021, 15:52
https://pbs.twimg.com/media/EzAyik-XIAA ... ame=medium
Hot air exit looks tighter
Hope it's real and not just illusion. Was expecting a smaller outlet, though, after maybe playing it safe at the first race and also because of the temperatures.
Obviously these angles are not conclusive but it certainly looks a lot tighter to me.
Giando
93
Re: Ferrari SF21
they certainly are (much) smaller outlets...
This should be the 'standard' spec, while the one in Bahrein is for hot temps
LM10
LM10
121
Re: Ferrari SF21
Seems like they’re comparing both versions. After red flags Sainz tested the Bahrain one while Leclerc had the right one.
aerofoilf1
aerofoilf1
247
Re: Ferrari SF21
New floor
ryaan2904
ryaan2904
36
Re: Ferrari SF21
Ferrari have done a respectable job this season
CFD Eyes of Sauron
wowgr8
wowgr8
29
Re: Ferrari SF21
I don't remember where I read that practice in Imola would be used as a test bed for future updates so this aligns with that. The question is, how would they be able to measure what difference that floor change makes? Wouldn't it be minuscule and require some sort of aero rake or flowviz?
wowgr8
wowgr8
29
Re: Ferrari SF21
Credit to the W10 for pioneering the shrink-wrapped sidepods. They make the cars look so muscular and shredded. It's also incredible engineering when you compare the S21 sidepods to the SF71 or SF90 ones
F1NAC
170
Re: Ferrari SF21
wowgr8 wrote:
16 Apr 2021, 12:29
They can ran 2 cars with different floors simultaneously on the track and track the data with same ambient conditions. Later verify that in WT.
Sainz ran new floor while Leclerc had older one.
aerofoilf1
aerofoilf1
247
Re: Ferrari SF21
Better view of the smaller cooling outlet. Bahrain race was V2.
gordonthegun
254
Re: Ferrari SF21
F1NAC wrote:
16 Apr 2021, 13:15
wowgr8 wrote:
16 Apr 2021, 12:29
In FP2, on Leclerc's crashed car I could see the new floor, so maybe they switched floors or they both used the new one.
Re: Ferrari SF21
F1NAC wrote:
16 Apr 2021, 13:15
wowgr8 wrote:
16 Apr 2021, 12:29
Ferrari had a huge mix of parts in FP1, floor, rear bodywork (the smaller hot air exits), trimmed vs non-trimmed FW... and they kept going through them.
Can't comment on FP2 cause i wasn't able to watch it.
Re: Ferrari SF21
Great shot via AMuS
sucof
Re: Ferrari SF21
Just made an interesting comparison :)
The middle part of the floor looks like as the same image, but it is not :) Also the length difference is clearly visible.
marcush
marcush
Re: Ferrari SF21
MtthsMlw wrote:
16 Apr 2021, 18:22
Great shot via AMuS
https://pbs.twimg.com/media/EzG7uNIWUAQ ... name=large
that floor looks like it has gone through
a plethora of modifications since it was
layed up first time.......
marcush
marcush
Re: Ferrari SF21
wowgr8 wrote:
16 Apr 2021, 12:29
they have their baseline data from the old floor on the other car and can get downforce data through load sensors in their pushrods and surelythey have some flow sensors to gather some aero
data.
If its worth anything the stopwatch should tell after the driver return with a broad gein visible under the helmet ....if not , back to the think tank ....
