Pulse-jet driven MGU-H turbo with a fully integrated MGU-K in the rear diff.
No battery! Spin em to win em!
It could be, but the sound of 20 of them at the starting line of the GP would be epic!Tommy Cookers wrote: ↑17 Jul 2021, 10:51isn't that a space heater ?
being as a PU less than 50% efficient
For reference, I notice the Porsche 919 Evo only revs to 8000rpm. So I guess that is what F1 would rev to, if the maximum fuel flow was available at any rpm and not from only above 10,500rpm?mclaren111 wrote: ↑17 Jul 2021, 12:34http://www.f1reader.com/list/news/lates ... ees-283849
I agree with Horner...
Clearly Wolff are after the money...
If you like the sound, you should rewatch some games from the world cup in South Africa 2010, a pulse jet and a vuvuzela sounds similar ...Zynerji wrote: ↑17 Jul 2021, 14:09It could be, but the sound of 20 of them at the starting line of the GP would be epic!Tommy Cookers wrote: ↑17 Jul 2021, 10:51isn't that a space heater ?
Not to mention the downsizing over an ICE, as well as 80kg of weight saving... Plus zero water cooling needed, just oil for the one moving part (turboshaft).
Vuvuzela's have turbochargers attached that alter the sound like the pulse-jet MGU-H that I've speculated?Holm86 wrote: ↑17 Jul 2021, 21:00If you like the sound, you should rewatch some games from the world cup in South Africa 2010, a pulse jet and a vuvuzela sounds similar ...Zynerji wrote: ↑17 Jul 2021, 14:09It could be, but the sound of 20 of them at the starting line of the GP would be epic!Tommy Cookers wrote: ↑17 Jul 2021, 10:51
That's not a pulse jetZynerji wrote: ↑17 Jul 2021, 21:34Vuvuzela's have turbochargers attached that alter the sound like the pulse-jet MGU-H that I've speculated?
Look at the device at 57 seconds. It is easy to imagine a MGU-H in between a split turbo being a pretty simple addition (other than obtaining one...). Why couldn't a setup like this run as a real-time 3phase electric generator and power a drive motor?
I'm pretty sure in the earlier build vids he referred to it as a turbocharged pulse jet. Please explain why it would not be?Holm86 wrote: ↑18 Jul 2021, 01:21That's not a pulse jetZynerji wrote: ↑17 Jul 2021, 21:34Vuvuzela's have turbochargers attached that alter the sound like the pulse-jet MGU-H that I've speculated?
Because that is a regular turbo jet, with s compressor stage, combustion stage, and turbine.Zynerji wrote: ↑18 Jul 2021, 01:25I'm pretty sure in the earlier build vids he referred to it as a turbocharged pulse jet. Please explain why it would not be?Holm86 wrote: ↑18 Jul 2021, 01:21That's not a pulse jetZynerji wrote: ↑17 Jul 2021, 21:34
Am I right in thinking the V1 flying bomb used a pulse jet?
Correct Marty, that's not a pulse jet, but this is, you can hear it pulsing,Marty_Y wrote: ↑18 Jul 2021, 02:51Am I right in thinking the V1 flying bomb used a pulse jet?
A pulse jet and the jet in that video sound very different to me.
Indeed, such an engine type was proposed recently, of course by VAG, although it was not clear if it should be a V4 or a four inline.
A inline 4 has much less moving parts then a V4 and is a lot easier in construction (with only one exhaust side instead of two), and only needs two simple structures on the side as a support... I don't see your logic.
Why not use the existing inline-four 2.0 from Super Formula, DTM and SuperGT? There are already six engines designed to this formula (Mercedes, Toyota, BMW, Nissan, Honda, Audi) which could have a hybrid system added.
