Scuderia Ferrari SF15-T
Nathanael F1
Nathanael F1
Re: Scuderia Ferrari SF15-T
Are the sidepod panels new? If I remember correctly they were one piece. Now they're separated above the intake.
Mr.G
34
Looks like Ferrari take this update quite seriously. I wonder how the far will perform. Good mind game against Mercedes :)
BanMeToo
BanMeToo
A bit surprising that Ferrari have so many updates ready! I'm excited to see how it affects their sessions this weekend...
Mr.G
34
I don't have SF15-T looked over so much, so maybe a dumb question - was the goldish cover on the top of rear crash structure there before? Looks like heat protection...
giantfan10
giantfan10
27
Mr.G wrote:I don't have SF15-T looked over so much, so maybe a dumb question - was the goldish cover on the top of rear crash structure there before? Looks like heat protection...
yea it was there .... there is a long drawn out debate about it being deposits from fuel additives somewhere on this forum
Fede90
Fede90
There is a very different approach to evolve the car this year. In 2013 and 2014 almost all upgrades have been useless, and the basic car was technical horrible
charlex
-4
Rivola has been fired?!?
f300v10
f300v10
185
Advino116 wrote:As far as I can tell, the coke bottle at the rear has not only been tightened slightly, the hot air exits have also been raised.
Agreed, the hot air exists are several inches higher than before. The rear pull rod used to go through the exit bodywork, now its the upper control arm inside the bodywork. I assume moving this higher would lead to more airflow between the rear bodywork and the floor.
tranquility2k4
tranquility2k4
At bottom of the rear wing end plates, a lot of cars have thin verticle fins but the horizontal ones at the front of the end plate - are these new and a unique design?
They have these fins since the beginning of the Season (i think they were there even in Pre Season testing).
markp
markp
The sidepods looked small before from similar angles to what we have seen so far. I know they have these scallops now but I will reserve judgement until we see 3 quarter view from behind, side on and top down pictures.
Beautiful.
The effect of this cut:
Reduced high pressure zone on leading edge of side pod.
Increased down-wash velocity to the coka bottle
Reduced frontal area and hence drag
Higher velocity going to the corner strakes (squirers) leading to the diffuser.
Hail22
144
charlex wrote:Rivola has been fired?!?
This is the technical thread for the SF15-T, perhaps make your post here:
http://www.f1technical.net/forum/viewto ... &start=210
Gilles Villeneuve
