Lotus E21 Renault
korzeniow
korzeniow
Re: Lotus E21 Renault
Huntresa wrote:
Blackout wrote:There is only one version. Lotus used two different rounded monkey seat though.
How do you know there is only one version ? If anything Lotus should have two since they have worked on it the longet.
Sure the low pipe isnt there on one and that might suggest its not the full version but then again why would they run a system that obv then wouldnt work if you need the low pipe?
That's because when they run without exit pipe the ears were closed, IIRC
February 5, 2013
korzeniow
korzeniow
I'm hoping for new pictures tomorrow, but meanwhile:
an old one from Malaysia
February 5, 2013
korzeniow
korzeniow
nice top view for comparsion
right click for hi-res of course
February 5, 2013
China 2013 - Thursday (11.04.2013)
via Matt Somerfield
ptw
ptw
There are two different ducts: one attached to the main plate and the other one - not attached
Maybe you confuse it with last years DRD whitch had an attached pipe
korzeniow wrote:nice top view for comparsion
http://i.imgur.com/lTn79dJ.jpg
http://i.imgur.com/7MeM82h.jpg
Looks like Raikkonen's right rear floor vane (that is made of metal and sits near the wheel) was broken
Kiril Varbanov
147
Latest updates from Piola on Kimi's E21
Blackout wrote: http://i.imgur.com/6sNq0en.jpg
I know. I mean the anti-roll bar and the steering rack especially... they were always exposed in the last Enstone cars. But now they're placed** inside the monocoque. It's just an observation. A monocoque that is, as you know, veeery similar to the E20 monocoque...
I wonder why they made that change... what could they gain...
Edit: **ARB seems to be placed inside..
Could it be Lotus is using 'exclusively' hydraulic suspensions like Mercedes (but only for the front) ? a hybrid FRIC : P ?
Owen.C93
Owen.C93
177
Where did we used to see the ARB?
In the E20 (on the top)
korzeniow
korzeniow
February 5, 2013
GrizzleBoy
GrizzleBoy
Blackout wrote:Maybe you confuse it with last years DRD whitch had an attached pipe
http://www.servimg.com/image_preview.ph ... u=14795526
Also shows the upgraded floor that Romain didn't get.
Forza
238
China GP - Friday - 12/04/2013
There is an interesting new part between the sidepod and its vertical deflector
what area are you talking about?
