Scuderia Ferrari SF15-T
Re: Scuderia Ferrari SF15-T
Monaco, Wednesday by AMuS
emmepi27
emmepi27
141
Good shot of radiator's inclination (octane)
And AMS
atlantis
atlantis
21
https://twitter.com/AlbertFabrega/statu ... 3924747264 Same new package seen in Barcelona.
atlantis
atlantis
21
PlatinumZealot wrote: WEll... Brake by wire as you know, is really changing the braking power by way of the KERS generator. The KERS unit is connected to the crankshaft and cannot discriminate between left or right wheel.
I thought that BBW was also directly controlling calipers :O.
My mistake then :)
Giando
93
Quite an interesting highlight about the new badge boards mounted in Barcelona, with a hidden double cut/fence on the the connection to the floor.
Source Omnicorse: http://www.omnicorse.it/magazine/55711/ ... -deviatori
lio007
320
Monaco, Wednesday by AMuS:
atlantis
atlantis
21
Advino116
Advino116
19
They are using the larger hot air outlet around the exhaust
atlantis wrote: The cooling opening looks new
It was there in Spain. Seems to be part of the new package
alexaxarlis
alexaxarlis
Its difficult to win at the Monaco circuit
atlantis
atlantis
21
Advino116 wrote:They are using the larger hot air outlet around the exhaust
Ah, thanks!
BlackSwan
BlackSwan
f1316
f1316
84
Kinda surprised they reintroduced the larger cooling around the exhaust - is it really hotter in Monaco than it was in China?
Top speed isn't a priority, downforce is, so I'm guessing it's more to do with that than actual cooling. Or maybe you do need more cooling since the average speeds are pretty low, Sepang has some slow speed stuff but it always leads to high speed stuff of which there is plenty of, in Monaco you're going slowly for half of the lap.
Yep, lower airspeeds, still developing the same amount of power/heat = more cooling needed.
f1316
f1316
84
That makes sense to be fair. Thanks:)
