Scuderia Ferrari SF71H
Re: Scuderia Ferrari SF71H
You are a genius !!
pimpwerx
pimpwerx
PhillipM wrote:
17 May 2018, 14:08
SparkyAMG wrote:
17 May 2018, 12:58
Sadly all halo mounted mirror stalks must now join the mirror on either its in-board surface or the bottom surface, and multiple stalks aren't permitted unless the structural requirement of said stalks are demonstrated.
"Okay Charlie, whatever you say, we've fixed the mirrors"
https://i.imgur.com/yNIM2Al.jpg
The requirement to mount on the inboard part of the mirror voids this design.
Wait...I see what you did there. Lol.
dans79
267
pimpwerx wrote:
17 May 2018, 18:04
what would really void that design or anything like them would be this.
"Whilst the FIA accepts that teams will legitimately design the mirrors, housings and mountings to minimise any negative aerodynamic effects they may cause, we believe that any aerodynamic benefits should be incidental, or at least minimal,"
http://www.f1i.com/news/304249-fia-publ ... nting.html
201 105 104 9 9 7
roon
roon
412
"Yes, Charlie. I assure you that any aerodynamic benefits of this design are minimal."
dans79
267
roon wrote:
17 May 2018, 18:58
Thankfully the teams don't get to decide what's minimal, the FIA does.
201 105 104 9 9 7
"I assure you, FIA, the aerodynamic advantages of these mirrors are less than the Force India mounts. I assume you're going to ban those first, right?"
e30ernest
e30ernest
27
I really think they should just outright ban mirror mounts on the halo. There's already a rule that prohibits any aerodynamic device a few centimeters around the halo. Having mirrors mounted there just creates loopholes like this.
That said, I doubt the photo with the mirror mounted on the winglet like that would have the desired effect they want. I think they want that open wingtip for vortex generation or they'd have gone with (or similar to) the solution pictured by PhillipM from the get go.
Big Tea
99
One clear option, and its a path I do not like going down, is a 'standard FIA supplied mirror and mount for HALO use' Such as the camera.
Not a fan of 'you must use this' but if it clears up problems then, consider it.
[media]https://twitter.com/andihaupt1/status/9 ... 39776?s=19[/media]
Note the three slots in the top sidepod leading edge.
f1316
f1316
84
There was some talk at the beginning of the year (from Vanja, no less :D ) that this sidepod area had been designed in such a way that different bodywork could be easily fitted at the sidepod opening to suit the needs of the track.
Given the max downforce/lower drag penalty nature of Monaco, I wonder if we’ll see something of this nature here - e.g. some very bulky, downforce-producing, mid-wing-type elements? Perhaps more similar to last year’s solution?
Interested to see what emerges but good to get this closeup for reference of how it might all fit together.
From the front
@SmilexTech
Still using the updated rear upper wishbone which was suspected to cause the tyre wear issues in Spain.
@AlbertFabrega
Mamba
Mamba
MtthsMlw wrote:
23 May 2018, 15:19
https://pbs.twimg.com/media/Dd4k1SrVMAEC8sV.jpg:large
@SmilexTech
https://pbs.twimg.com/media/Dd4lLE8U0AEljTK.jpg:large
@AlbertFabrega
Well there was a two day test after spain so they must have determined that the new suspension could not have been the cause since it is on the car again.
f1316
f1316
84
Mamba wrote:
23 May 2018, 15:33
MtthsMlw wrote:
23 May 2018, 15:19
@SmilexTech
@AlbertFabrega
Or that it’s not a problem in Monaco (maybe has better warmup).
Mamba
Mamba
f1316 wrote:
23 May 2018, 15:41
Also very possible. I think I read somewhere that Pirelli say the Hypersoft is good for something like 77 laps around Monaco so tyre wear will be much less of an issue here. We will have to see in Canada then...
