wogx wrote: ↑15 Nov 2021, 01:01
https://streamja.com/zPZAM
Why LH is moving the steering wheel back and forth? DAS was banned for 2021
![Eh? :-s](./images/smilies/icon_eh.gif)
Maybe it's a new system?
I am no engineer, but I guess the answer is pretty simple. If you head down a straight with nearly 300km/h and then jump on the brakes, there is quite a bit of force on the pedal. To get that force you need to create quite a bit of pressure on the peddal. as the stearing wheel is the other point of contact, this is where you react. Grip it hard to brake hard.
Do you have onboard footage of all the other drivers? I would suspect that this is the case for most of them. A few could grip the seat with their a**, personally I would prefer the steering wheel as well
