Mercedes-AMG F1 W10 EQ Power+
OO7
OO7
171
Re: Mercedes-AMG F1 W10 EQ Power+
From AMuS regarding Mercedes' upgrades:
Mercedes has brought only minor modifications to Silverstone. This will be upgraded in Hockenheim again. It's a big upgrade. "This will be obvious to everyone," says an engineer.
Via AMuS
Less cooling outlet on the sidepod than in Austria
Via Motorsport.com
zibby43
zibby43
astracrazy
astracrazy
31
Blaze1 wrote:
11 Jul 2019, 14:26
Sounds Austria style from last year...
zibby43
zibby43
zibby43
zibby43
Via Scarbs; gives you an idea how the mainplane is set up. Also nice scale for the DRS actuator.
OO7
OO7
171
Engine Cover for Austrian GP:
Note the contour of the engine cover and the twin blisters by the "44".
Engine Cover in for British GP:
Note the contour of the engine cover and the blister closest to the "44" is less pronounced or even missing.
A different T-wing is also visible. I think it was used in pre-season testing or last year?
Maybe the 'blister' is missing because it's the other side of the car?
OO7
OO7
171
MtthsMlw wrote:
12 Jul 2019, 11:18
It's usually a mirror image of the other side.
101FlyingDutchman
101FlyingDutchman
Those blisters are the mounting points which are FIA regulated so even though they can narrow the body work down around it, the mounting points are fixed in “space”
OO7
OO7
171
101FlyingDutchman wrote:
12 Jul 2019, 12:41
I think one pair 'may' be due to the mounting points, but at least one pair is present because of the small radiator.
henry
324
12 Jul 2019, 12:41
Mounting points for what?
OO7
OO7
171
henry wrote:
12 Jul 2019, 13:14
12 Jul 2019, 12:41
The top mounts where the engine and gearbox/gearbox casing mate.
OO7
OO7
171
12 Jul 2019, 12:41
Looking at that picture again and comparing with the following:
The standard mounting points aren't the cause of those blisters, they are purely for the small cooling radiators and more specifically to also accommodate the pipework to those rads.
henry
324
Blaze1 wrote:
12 Jul 2019, 13:47
henry wrote:
12 Jul 2019, 13:14
12 Jul 2019, 12:41
Thanks. But I think you’ll find those connections are much further forward, 480mm behind the survival cell bulkhead.
