Ferrari F10
adrianjordan
Re: Ferrari F10
Morteza AMG wrote:
So it appears they have dropped he EBD for Monza...any ideas why??
I mean obviously they feel the car is less draggy without it, but why would the EBD generate more drag than any other exhaust arrangement??
timbo
timbo
111
Re: Ferrari F10
adrianjordan wrote:I mean obviously they feel the car is less draggy without it, but why would the EBD generate more drag than any other exhaust arrangement??
The reason might be not aero, but engine performance related.
I don't think EBD is efficient exhaust config.
adrianjordan
Re: Ferrari F10
Interesting, thanks.
Re: Ferrari F10
I still see the EBD plate.. I think it's still there until I see photos of the side-pods that is.
zgred
Re: Ferrari F10
timbo
timbo
111
Re: Ferrari F10
From this pic it seems EBD is still there.
230
Re: Ferrari F10
It's only deeper into the side pod.
It may be negligible but the ebd takes away some of the exhuast thrust, because of the downward component of force onto the diffuser, intead of a purely horizontal stream of hot gases. Maybe setting it back a little may dilute the ebd effect a little. Just some speculation by the way.
Or it could simply be an evolution of the ebd that we will see at all races from now on.
raymondu999
Re: Ferrari F10
The front wing is single element. Less drag perhaps?
失败者找理由,成功者找方法
imightbewrong
imightbewrong
Re: Ferrari F10
raymondu999 wrote:The front wing is single element. Less drag perhaps?
No, they just haven't mounted the upper element. It is connected to the f-duct so they usually mount it later.
gridwalker
gridwalker
Re: Ferrari F10
That is impressive : how did they manage to f-duct a FRONT wing??? #-o
raymondu999
Re: Ferrari F10
gridwalker wrote:That is impressive : how did they manage to f-duct a FRONT wing??? #-o
I think he might be wrong. :P
失败者找理由,成功者找方法
imightbewrong
imightbewrong
Re: Ferrari F10
Doh! I better learn to read... I saw the last photo of the rear wing and thought he was talking about it, since it was missing the upper element in that picture :oops:
And I think you might be right :wink:
ell66
ell66
Re: Ferrari F10
they did the same for spa, like you said it decreases drag.
imightbewrong
imightbewrong
Re: Ferrari F10
They kind of use (was it marcush's idea?) of narrowing the rear wing and f-ducting a more steep rear-wing than necessary. Only that they have the full width, but the center section is higher than the edges. Same idea, but with less radical implementation.
Re: Ferrari F10
ah sigh of relief there..but not as radical as i had in mind ... :roll:
