Mercedes AMG F1 W04
BlackMercedes
BlackMercedes
Re: Mercedes AMG F1 W04
I think Lewis main issue is the brake cylinders he mentioned obv at mclaren they had them spot on being in the team so long
MercedesAMG
MercedesAMG
Ferraripilot wrote:Is that just on Lewis' car again?
I think on both, but I'm not sure.
Forza
238
If you look at the FW you can see them on both cars
Canadian GP - Friday FP - 7/6/13
BlackMercedes
BlackMercedes
Both cars had the infra red senors on
atanatizante
125
Kiril Varbanov wrote:
mantikos wrote:ballast weight - kept low for lower CoG
Indeed, looks like a tungsten steel ballast - the estimated weight of this piece is about 8 to 10 kilograms.
Which one? Red or green arrow?
Jesus
mantikos
mantikos
http://i.imgur.com/fMkSB3w.jpg
Green
The red looks like link up for vertical splitter above the tea tray (based on the triangular shape and location)
diego1960
Ferraripilot wrote:I'm not quite seeing different side pods or any alterations to the exhaust, can anyone point this out a bit more clearly if that is indeed the case?
I too can't see anything. Even slight differences. It appears as though the only modification was the new engine cover.
"Being second is to be the first of the ones who lose." - Ayrton Senna
lebesset
lebesset
monsi wrote:Lewis's column on the BBC site is describing his braking issues http://www.bbc.co.uk/sport/0/formula1/22809074. I'd be surprised if Mercedes was not working on that, if only because the way he describes it as a loss of 0.3s in the first sector of Monaco is three times the scale of the improvement estimated above. What do people think are the options that might be appropriate ? Are 'simple' measures like tyre conditioning or blanket temperatures feasible, or is it all much more complicated than that ?
although I was aware that MGB have changed the pad material this year because last year's didn't allow lewis to use his normal technique of stamping on the brakes ultra late , and that nico has decided to change to that as well , I didn't realise that some teams have exclusives on the material they use so that it can't be offered to their competition
to the optimist a glass is half full ; to the pessimist a glass is half empty ; to the F1 engineer the glass is twice as big as it needs to be
via Ferran F.
BlackSwan
BlackSwan
also mercedes is monitoring tyre temperature like Ferrari?
Forza
238
Tobias Grüner wrote: Mercedes AMG running new front brake ducts without the extra duct on the inside they had yesterday
Canada 2013 - Saturday (08.06.2013)
diego.liv
diego.liv
As we've seen those last years, copying in F1 is retentionless: Merc's unique style front wing has its design in something specific (more front DW, vortex generated,...) or copying another design would be unuseful?
Joie de vivre
well the problem is clear, they suck at race. why? probably heavy fuel load due to high consumption. they really should consider revising the exhaust and maybe engine mapping. maybe this is also the reason behind high tyre degredation. when toro rosso started using rbr styled exhaust they started to score some good points in the race. i presume they aren't focusing enough on that problem
