Ferrari F1-75
gordonthegun
254
Re: Ferrari F1-75
Re: Ferrari F1-75
Vanja #66 wrote:
25 Jul 2022, 07:36
Blackout wrote:
25 Jul 2022, 00:43
Did they sculpt the red area so that created a front facing step (red arrow) that looks like the RB one?
Left pic = Imola (AMuS) - right = French GP @DANIELEALOFAN
The mini diffusers at the boat tail are still there but not very visible, or not as agressive ?
https://pbs.twimg.com/media/FYdyjblXgAA ... ame=medium
Great comparison angles, as expected this is a completely new floor altogether. They did what RB did with the step (red arrows), using it to narrow down the keel to let more air to the floor, then introduce a hard outward flick to help run the air outwards to the throat. The chassis department is doing the best job on the grid, the car is perfect in all conditions.
What is the benefit of that?
Re: Ferrari F1-75
Blackout wrote:
01 Oct 2022, 20:22
Pushing more air through the throat speeds the air up if done right. If not, it will choke the throat and stall the floor.
Adding this abrupt curvature in that area also reduce the pressure on its own, so it looks like a double benefit. No wonder RB did it from the start of the season.
SmallSoldier
SmallSoldier
479
Re: Ferrari F1-75
Ferrari building the F1-75 in Japan:
SmallSoldier
SmallSoldier
479
Re: Ferrari F1-75
According to Albert Fabrega, Ferrari will be trying a new floor in Suzuka:
Re: Ferrari F1-75
Update: Photo 1 the Suzuka bottom with tie rod anchor moved more centrally on the chute. (Photo 2 standard bottom) Change signaling a different ability of the edge to lower at lower speeds. Interesting test
seems maybe like the kick points have changed too ?
Re: Ferrari F1-75
06 Oct 2022, 09:54
"Cool" idea, Ferrari gave up on making big modifications for this seasons end, a proposed new floor was ditched because it wouldn't fit the budget, so might as well experiment the benefits of some "tinkering".
Re: Ferrari F1-75
Source: Craig Scarborough on Twitter [@ScarbsTech]
Update to the shape of the outboard "bargeboard" floor fence. Seems Charles is set up to run the old floor whilst Carlos is testing the new one.
tpe
tpe
-4
Re: Ferrari F1-75
06 Oct 2022, 09:54
Do the have a "kick" point? For this angle looks like the incline is flat and that there is a "tube" like section.
Also, it looks a bit tighter back there, but it could be just an illusion due to the angle.
Re: Ferrari F1-75
Andi76
Andi76
422
Re: Ferrari F1-75
06 Oct 2022, 17:43
The orientation of the carbon fibres has also changed.
FDD
FDD
78
Re: Ferrari F1-75
Andi76 wrote:
06 Oct 2022, 19:56
06 Oct 2022, 17:43
The orientation of the carbon fibres does not matter at all, carbon weave structure is made to absorbs the forces in all lines/straights equally
Re: Ferrari F1-75
FDD wrote:
06 Oct 2022, 23:01
Andi76 wrote:
06 Oct 2022, 19:56
06 Oct 2022, 17:43
This is very incorrect.
Andi76
Andi76
422
Re: Ferrari F1-75
FDD wrote:
06 Oct 2022, 23:01
Andi76 wrote:
06 Oct 2022, 19:56
06 Oct 2022, 17:43
Are you serious? You just said carbon fibre orientation does not matter in relation to F1? So you can just change it for fun? +45, -45, Unidirectional, Plain, TWill. It does not matter what you use anyway! And you can throw away the ply books? Yes!!! Great!!! #-o äähm..sorry, but no. What you say is just utter rubbish. I suggest you to do some research about F1 underfloor design and carbon fibre orientation.. and by the way - no one would like such a floor!!!
Re: Ferrari F1-75
FDD wrote:
06 Oct 2022, 23:01
Andi76 wrote:
06 Oct 2022, 19:56
06 Oct 2022, 17:43
Really. Where have you been the last forty years? I think we have to arrest you and take you to F1 technical jail for the crime you just committed!
