Not anymore they're not. The vent in to the airbox was banned as part of the oil-burning clampdown.
All of them blow the crankcase vent out the back of the car now.
Right I got it, I know how merc are cheating. Their oil has lots of solvents which burn off when the engine warms and after the race they top up, as allowed, with very very heavy oil. Just think how much weight they can saveispano6 wrote: ↑15 Aug 2020, 01:00Does that make plumes of white/bluish smoke/vapor ok?Mudflap wrote: ↑13 Aug 2020, 19:00It's coming out of the breather. How do you explain that ?ispano6 wrote: ↑13 Aug 2020, 18:20Anyone else think it's just a matter of oil consumption being proportional between quali and race. If you use the quali mode in the race you exceed consumption limits. This rule simply makes it so that you cannot have an advantage in quali that you wouldn't have over the span of a race. Or am I unique in thinking so.
Drivers don't need modes to protect an engine, they just shouldn't mash the pedal all the time, they need to modulate their pedal inputs with their feet, like microsteering.
To the same boys down voting every comment I make with regard to oil consumption, watch this video. Oil, additive, water, whatever you want to call it.
https://www.reddit.com/r/formula1/comme ... _mercedes/
https://www.auto-motor-und-sport.de/for ... ali-modus/Both measures [Quali mode ban and futher aero restrictions] come out of the blue. The restriction to one engine setting for qualifying and racing is justified by the fact that it is becoming increasingly difficult to check whether the drive units are being operated in accordance with the rules. The Ferrari case was a warning to the FIA. The FIA only found out about the tricks when a competitor provided information about the alleged fraud. Also now there are apparently again doubts about at least one of the four drive units.
The FIA has asked the engine manufacturers to provide detailed information on the ERS architecture, as well as drawings and three-dimensional CAD views of all auxiliary circuits that are not part of the high-voltage circuit, by 21 August. In case of doubt, physical checks would be carried out on the car. The sudden distrust allows only two conclusions. Either there is suspicion, or the FIA is actually groping in the dark.
Interesting. I noted that during FP2? Karun said his sources indicated that the information released to the public was less than 30% of the directive and there were many important technical details omitted. Perhaps that is some of what he was talking about.MtthsMlw wrote: ↑15 Aug 2020, 13:15Tidbit from AMuS about the matter:https://www.auto-motor-und-sport.de/for ... ali-modus/Both measures [Quali mode ban and futher aero restrictions] come out of the blue. The restriction to one engine setting for qualifying and racing is justified by the fact that it is becoming increasingly difficult to check whether the drive units are being operated in accordance with the rules. The Ferrari case was a warning to the FIA. The FIA only found out about the tricks when a competitor provided information about the alleged fraud. Also now there are apparently again doubts about at least one of the four drive units.
ive said since the beginning of this season that Mercedes had something up their sleeve - chassis or engine
So what? They can learn to micro pedal. Have you ever driven a Tesla with one pedal?zibby43 wrote: ↑13 Aug 2020, 20:34Dans79 is absolutely right. I read your comment the same way. You pretty explicitly state that the driver can just let his foot off the throttle a bit and manage the engine that way.
That’s not how this works in F1.
Letting off the throttle in an F1 car has a significant (monumental) engine braking effect. It’s not like modulating the pedal in a road car on the highway where you go “Hmm, take a bit off here to go 65 mph instead of 70.”
So constructors can compete on a level playing field obviously, and engine development costs can be reduced greatly for manufacturers. V8 Supercars has operated on a fixed cumulative horsepower limit (hp integrated over rpm) with all engine parts needing to be homologated (and being open for the inspection of rival engine builders) for quite some time. It has greatly reduced costs (and the frequency of blow-ups!) compared to the days when engine builders were free to develop the small block Ford and small block Chevrolet engines for maximum horsepower.El Scorchio wrote: ↑14 Aug 2020, 14:10Why do you keep saying they NEED to equalise the engines? What is the need?
Indeed V8 Supercars still use cable-operated throttles (by regulation).
If it is not "historic" racing, then why does F1 require hydraulic power steering by regulation, instead of the electric power steering as fitted to 99% of modern vehicles!?
Oil mixed with blowby.
I'm not sure you are familiar with an F1 car's hydraulic system but it is far from being outdated technology. Actually it is far more similiar to aircraft hydraulics than anything you'd find in a road car and the reason they use that instead of electric motors is because it is much lighter for the power required.JordanMugen wrote: ↑15 Aug 2020, 17:20If it is not "historic" racing, then why does F1 require hydraulic power steering by regulation, instead of the electric power steering as fitted to 99% of modern vehicles!?
Some times there can be other regulatory reasons for mandating outdated technology.
There is no rule that Merc have to call the 'mode' the same thing all the time, its just switch positions like 'set to 11' like spinal tapzibby43 wrote: ↑15 Aug 2020, 20:14An Italian journalist has indicated that Mercedes did not use their qualifying mode in Q3 today.
Edit: Welp, there seems to be some good evidence that Mercedes did use a lower qualifying mode today in Q3.
https://twitter.com/Gianludale27/status ... 01442?s=20
"Mercedes has always used strat 2 for the last part of the qualification, which is the most powerful. Today they used strat 3 for the last part of the qualification (with Bottas it's easier if you want to see). I throw it there, then free space for interpretation #SpanishGP"
https://twitter.com/AnnotatedWA/status/ ... 75041?s=20
Merc normally, for every quali sessions, runs Strat 2 for the final Q2 and all Q3 runs.
Today, Merc used Strat 3 for the final Q2 and all Q3 runs.
Oh boy.
