Lotus E21 Renault
Neno
Neno
-29
Re: Lotus E21 Renault
Kansas wrote:Awfully similar apart from the exhaust
I dont know what is similar to you except some color on this car. Night and day from nose to chassis, then sidepods and rear. You can only say similar is rear wing. Most changes are made where car needed upgrades, end of car, rear downforce.
Reason: Removed image quoted from earlier post
Kansas
Kansas
-3
Neno wrote:
Kansas wrote:awfully similar apart from the exhaust
Night and Day?? i can spot very very very small differences and thats all.
The black of course makes the differences harder to spot. There are obvious differences if you study the car closely, like a much more undercut roll hoop, the chassis at the splitter is differently curved, the sidepods are a tiny bit higher and the nose too is somewhat higher and flatter (if you think away the bulge under the nose for a second). Overall, it's the exact same philosophy all around the car, just with some optimalisations and red bull ramp.
MarkedOne8
MarkedOne8
I agree with turbof1. On first look, the E20 and E21 both look pretty simmilar. But, as turbof1 and I said, the black color makes it really hard for the differences to be spotted. Almost everything is revised or changed. Tweaking, tweaking, tweaking.
Fernando Alonso is the best pay-to-drive driver in F1 with the biggest amount of money behind him.
http://f1bias.com/2012/04/05/truth-abou ... nder-2008/
Kansas
Kansas
-3
turbof1 wrote:The black of course makes the differences harder to spot. There are obvious differences if you study the car closely, like a much more undercut roll hoop, the chassis at the splitter is differently curved, the sidepods are a tiny bit higher and the nose too is somewhat higher and flatter (if you think away the bulge under the nose for a second). Overall, it's the exact same philosophy all around the car, just with some optimalisations and red bull ramp.
was hoping for more agressive design.
Kinda pain to witness 2013 car to suffer on wet track again with such minimal changes.
MarkedOne8
MarkedOne8
If they solve the problems in wet, you are not going to see it on bodywork. It's up to suspension or other mechanical settings.
Kansas
Kansas
-3
MarkedOne8 wrote:If they solve the problems in wet, you are not going to see it on bodywork. It's up to suspension or other mechanical settings.
i don't see any changes on rear suspension.
Probably they wanna retain the gentleness of E20 on tyre.
korzeniow
korzeniow
Both front and rear suspensions are revised. I don't know how you can't see this. Just look where are mounting points on this comparsion photo:
February 5, 2013
Bodywork, cooling, suspensions...
Kansas
Kansas
-3
Gary Andseron 's view on E21 's rear suspension:
There’s nothing trick here and it’s relatively conventional. Lotus certainly hasn’t gone as far as Red Bull in trying to minimise the disruption of airflow to the Coke bottle.
F1 Fanatic
Different tunnels compared to the RBR, especially their angle... and drive shaft is not covered...
Kansas
Kansas
-3
Blackout wrote:Different tunnels compared to the RBR, especially their angle... and drive shaft is not covered...
Craig Scarborough ‏@ScarbsF1
@nasce1 not enough pics yet, but their tunnels are simpler than RBRs
MarkedOne8
MarkedOne8
Lotus team trolling with screens to cover their garage. Wondering what are they going to do now or the session is over for them?
Kansas
Kansas
-3
Courtesy to SomerF1
Matt Somerfield ‏@SomersF1
@nasce1 @suttonimages @Lotus_F1Team There are minor differences between the two pic.twitter.com/jOLLkcg4
