Why is POU suspension banned?the EDGE wrote: ↑23 Feb 2022, 22:18The race say it’s to try to replicate the effect of POU suspension that’s now outlawed, lowering the front when you apply lockBandit1216 wrote: ↑23 Feb 2022, 22:11Tim.Wright wrote: ↑23 Feb 2022, 20:07From a first approximation, I don't see the anti-dive as being so high. The lower wishbone is also tilted back as well which reduces the anti-dive effect drastically.
https://dm2306files.storage.live.com/y4 ... pmode=none
This baffles me. Looks like neutral ackerman, quite some camber, but huge caster. But why? I would think with ground effect cars, one would want minimum roll and pitch, but caster hints at high roll imo.
It's not banned directly. It's banned indirectly by Article 10.2.6bNtsParadize wrote: ↑24 Feb 2022, 01:49Why is POU suspension banned?the EDGE wrote: ↑23 Feb 2022, 22:18The race say it’s to try to replicate the effect of POU suspension that’s now outlawed, lowering the front when you apply lockBandit1216 wrote: ↑23 Feb 2022, 22:11
You essentially have to design a suspension geometry that maintains the ride height within a very tight tolerance with steering input lock to lock. Therefore a POU design cannot function.
In addition, the following systems or configurations are not permitted:
Any coupling of the suspension systems to the braking or steering systems. To ensure
this is the case, any variation of ride height caused by the suspension geometry’s
kinematics and the tyre shape must not exceed 3mm over the range of steering lock
defined by Article 10.3.7.
Exactly correct. If generating dirty air is a byproduct of designing a quick "front running" car, then that's a perk. But no engineer in their right mind would prioritize the former for the latter.
This.cheeRS wrote: ↑24 Feb 2022, 02:21Exactly correct. If generating dirty air is a byproduct of designing a quick "front running" car, then that's a perk. But no engineer in their right mind would prioritize the former for the latter.
I have just posted directly above you.PlatinumZealot wrote: ↑24 Feb 2022, 02:11At people saying POU is banned I don't see any ruling that says POU is banned though?
Do you mean that it can't be sticking outside of the brake duct area? Because you can still do a little POU, though a short one and it would be out of sight.
Excessive caster causes jacking against the chassis doesn't it?AR3-GP wrote: ↑24 Feb 2022, 03:14I have just posted directly above you.PlatinumZealot wrote: ↑24 Feb 2022, 02:11At people saying POU is banned I don't see any ruling that says POU is banned though?
A POU design is not banned explicitly. However it is now illegal for rideheight to change when the steering wheel is turned. Therefore there is no incentive to run POU geometry. The purpose of POU was to make sure the ride height lowered when the steering wheel turned.
I would expect it would be better to reduce (kingpin inclined toward driver) the inside wheel instead of increasing the outside one? Maybe a bit of both?godlameroso wrote: ↑24 Feb 2022, 04:38Excessive caster causes jacking against the chassis doesn't it?AR3-GP wrote: ↑24 Feb 2022, 03:14I have just posted directly above you.PlatinumZealot wrote: ↑24 Feb 2022, 02:11At people saying POU is banned I don't see any ruling that says POU is banned though?
If the caster angle lowers the outside tire, that also lowers the wing on that side. Newey makes his cars generate their peak downforce when they're cornering, cause that's when the car needs the downforce the most. That's how you know this is just a preview version.Zynerji wrote: ↑24 Feb 2022, 04:47I would expect it would be better to reduce (kingpin inclined toward driver) the inside wheel instead of increasing the outside one? Maybe a bit of both?godlameroso wrote: ↑24 Feb 2022, 04:38Excessive caster causes jacking against the chassis doesn't it?AR3-GP wrote: ↑24 Feb 2022, 03:14
A POU design is not banned explicitly. However it is now illegal for rideheight to change when the steering wheel is turned. Therefore there is no incentive to run POU geometry. The purpose of POU was to make sure the ride height lowered when the steering wheel turned.![]()
Wouldn't loading the entire wing do the same?godlameroso wrote: ↑24 Feb 2022, 04:50If the caster angle lowers the outside tire, that also lowers the wing on that side. Newey makes his cars generate their peak downforce when they're cornering, cause that's when the car needs the downforce the most. That's how you know this is just a preview version.Zynerji wrote: ↑24 Feb 2022, 04:47I would expect it would be better to reduce (kingpin inclined toward driver) the inside wheel instead of increasing the outside one? Maybe a bit of both?godlameroso wrote: ↑24 Feb 2022, 04:38
Excessive caster causes jacking against the chassis doesn't it?![]()
Ok now you are talking clearer, because one could mount the push rod on the King pin axis as a POU and not get any ride height change with steering. This is why I asked.AR3-GP wrote: ↑24 Feb 2022, 03:14I have just posted directly above you.PlatinumZealot wrote: ↑24 Feb 2022, 02:11At people saying POU is banned I don't see any ruling that says POU is banned though?
