Mercedes W15
Venturiation
Venturiation
98
Re: Mercedes W15
Re: Mercedes W15
Better comparison images of new suspension locations. Significantly lower in 2nd pic. Interesting
Dr_obbs on twitter for photos
Re: Mercedes W15
Wow, that's not what you want to do unless you aren't sure what to expect from your suspension :shock: Compliance alert, code red level 5 :shock:
kenshi_blind
Re: Mercedes W15
The launch renders did show 2 different pick up points and two suspension arm so it seems it was well planned before testing. not sure how is that an alert code red level 5 and whatnot :wtf: ](*,)
f1rules
f1rules
597
Re: Mercedes W15
but its incredible smart that they can do, instead of building in a flaw that cant be changed the whole year, incredible if they made it modular
kenshi_blind
Re: Mercedes W15
f1rules wrote:
23 Feb 2024, 13:13
Agreed ,seems like a clever way to go testing and learning which development path to pursue
Holm86
247
Re: Mercedes W15
f1rules wrote:
23 Feb 2024, 13:13
Definitely a good idea, seems like they're testing what amount of anti dive is needed, or maybe they've thought about it being track specific, if its a balance between anti dive behavior and aero, faster tracks with less braking zones might benefit more from the aero advantage than the anti dive advantage
Luscion
Luscion
99
Re: Mercedes W15
f1rules wrote:
23 Feb 2024, 13:13
agreed, seems like the renders were showing it the entire time
Marble
Marble
Re: Mercedes W15
some more angles :
Luscion
Luscion
99
Re: Mercedes W15
Wonder if Merc are planning to go to slimmer sidepods
prox
Re: Mercedes W15
I don't think the adjustable suspension is a new thing, I can remember a long wheel based McLaren had moveable front suspension, so they could set it up for different tracks. Monaco inparticular was one track they would reduce the wheel base by moving the suspension backwards.
Holm86
247
Re: Mercedes W15
prox wrote:
23 Feb 2024, 16:36
If i remember correctly it was Mercedes also, and it was not adjustable suspension, or modular like this.
It was track specific front wishbones used for Monaco only that pulled the front wheels slightly back
Venturiation
Venturiation
98
Re: Mercedes W15
CaribouBread
CaribouBread
101
Re: Mercedes W15
Venturiation wrote:
23 Feb 2024, 18:51
The changeable front susp. is a fun thing but I have a niggling thought, shouldn't they have a solid idea what to go with even before they turn a lap - both on kinematics and aero effects? This surely isn't going to be change from race to race. I don't like that they're still looking for a direction on the front susp. - doesn't inspire confidence in my opinion. :?
Zynerji
110
Re: Mercedes W15
CaribouBread wrote:
23 Feb 2024, 18:55
Venturiation wrote:
23 Feb 2024, 18:51
I expect the adjustable part would be replaced after FP3 with a "solid" part that weighs less. Like a 3d printed bushing.
