McLaren MCL33
thestig84
Re: McLaren MCL33
Jef Patat wrote:
06 Mar 2018, 12:53
Avocado wrote:
06 Mar 2018, 12:08
New nose! Very interesting.
What has changed?
Nothing as far as I can see
Sieper
73
Re: McLaren MCL33
That is a good picture (plus for you) to me these kind of updates are much better then shouting, proof indeed that it is the same part (except with the 3 holes added).
McHonda
McHonda
Re: McLaren MCL33
Sieper wrote:
06 Mar 2018, 12:58
(Cheers), Yeah they've definitely added extra cooling on it so it looks like a stop gap measure to finish the tests so hopefully it works.
I think something will be tweaked around there for Melbourne.
Jolle
Jolle
133
Re: McLaren MCL33
McHonda wrote:
06 Mar 2018, 13:01
Sieper wrote:
06 Mar 2018, 12:58
With a careful conclusion that the problem is/was a bit bigger then a "two dollar" bolt that broke.
Avocado
Avocado
Re: McLaren MCL33
thestig84 wrote:
06 Mar 2018, 12:55
Jef Patat wrote:
06 Mar 2018, 12:53
Avocado wrote:
06 Mar 2018, 12:08
What has changed?
I thought it's curvier but I see now that it looks the same.
Avocado
Avocado
Re: McLaren MCL33
Re: McLaren MCL33
Jolle wrote:
06 Mar 2018, 13:13
Not really, it could still just be a 2 dollar clamp that got a little too hot and broke. Everyone is going nuts about it but it caused them no issues running the car once they fixed it.
I would imagine they will just run new covers with thicker ceramic insulation sprayed on there. Most internal heat-shielding isn't finalised until after the first tests - that's normal for every team.
lio007
320
Re: McLaren MCL33
And here's the result of their flow-viz run before the lunch break:
by AMuS
bauc
Re: McLaren MCL33
From the picture above, you can clearly see a pattern showin air being sucked towards the flour openings =D>
matt_s
matt_s
Re: McLaren MCL33
bauc wrote:
06 Mar 2018, 15:14
..air being sucked towards the flour openings =D>
Well, at yeast they will have something for lunch, but their pace kneads some work.
bonjon1979
bonjon1979
30
Re: McLaren MCL33
bauc wrote:
06 Mar 2018, 15:14
Presumably to try to seal the sides of the floor but in doing so sacrificing airflow over the top of the diffuser at the back. I'm sure it must be a net benefit though, otherwise they wouldn't've done it. It could be it allows them to run more rake?
bauc
Re: McLaren MCL33
bonjon1979 wrote:
06 Mar 2018, 15:40
bauc wrote:
06 Mar 2018, 15:14
I think its meant to feed the diffuser
Jef Patat
Jef Patat
Re: McLaren MCL33
First you say are being sucked down and then you say to feed the diffuser? :?
bauc
Re: McLaren MCL33
Jef Patat wrote:
06 Mar 2018, 16:20
Air sucked under the floor and driven towards the diffuser (bottom side) ?
Jef Patat
Jef Patat
Re: McLaren MCL33
That's completely wrong. You don't want air to be fed under the floor, certainly not from that area. The slots and vortex generators in those positions are there to seal the floor, to form kind of a barrier so that no extra air flows under the floor in an uncontrollable way, they help to make the downforce more uniform and keep dirty air away -> https://www.jamesallenonf1.com/2017/12/ ... the-slots/
