Williams FW37 Mercedes Speculation Thread
Re: Williams FW37 Mercedes Speculation Thread
They could do this with the Martini strips in order to make that nose look more alegant :| :)
FrukostScones wrote:
Blackout wrote:An 'M' shaped second cross section :?: (inverted U + T) ?
Or is it just just a 'T'...
just a T me thinks
Sth like this:
-second section
-first section
Neno
Neno
-29
tip of the nose almost looks like "puzzle"
McMrocks
McMrocks
32
I thought concave cross-sections are banned by the last paragraph of article 15.4.3
Furthermore, all lines drawn normally and externally to a vertical cross-section taken 150mm ahead of the front wheel centre line and perpendicular to the car centre line, must not cross a vertical longitudinal plane lying on the car centre line.
If you draw a line normally to the inside of the vertical extensions of the second cross section (picture posted by Blackout) they will cut the "vertical longitudinal plane".
The cross section is correct but the pylons (holding the fw) are not part of the impact absorbing structure.
:wink:
So the lower part of the nose can be concave from the tip to a point situated 150mm ahead of the wheel center line IMO.
McMrocks
McMrocks
32
:wink:
ok got it :oops: :)
edit: and who ever gave that up-vote, feel free to remove it
Vary
Vary
To me, it looks like a fw36 with a photoshopped nose... Even the livery is almost the same (this could be a "provisional" one like last year)
Mesteño
To me looks tinier in the rear.
Good lookin!
Ayrtonx100pre
Ayrtonx100pre
Interesting nose, no one sketched one quite like this.
Clearly an evolution of last years concepts other than that, similar sidepods and body.
bonjon1979
bonjon1979
30
Looks exactly like the Merc nose with a smaller little nubbin dick on the end.
bigger secondary air inlet behind the driver's head, too. definately not the FW36 with an updated nose.
Don't think this is the final product though, but i'd assume the nose won't change much. unfortunately.
GoranF1
GoranF1
155
Breaking news: The man who writes nose regulations for the FIA just got fired! They put up whit him for years and they had it!
GoranF1
GoranF1
155
Manoah2u wrote:bigger secondary air inlet behind the driver's head, too. definately not the FW36 with an updated nose.
and Mercedes style(wide) lower wishbone front suspension!
No one got to the inside pages yet? Last year it had more stuff.
Blackout wrote:They could do this with the Martini strips in order to make that nose look more alegant :| :)
http://wtf1.co.uk/wp-content/uploads/20 ... Ii5hE9.jpg
This would be option 1, option 2 would be to paint the tip black like Red Bull... it fools you on TV at least.
Sadly Williams doesn't seem interested (if anything it looks worst than what they had last year)
