Ferrari SF23
FDD
FDD
81
Re: Ferrari SF23
If they use a "heavier" BW it is very likely that they'll use FW with higher DW than they used on tests.
Any pictures someone?
Andi76
Andi76
434
Re: Ferrari SF23
Vanja #66 wrote:
02 Mar 2023, 13:24
That last one is F1-75, I posted it for beam wing comparison, sorry for confusion :)
Sorry guys my mistake - or Vanja's since he confused me :lol: . No sorry - was not paying attention, thought it was a new photo from today
Re: Ferrari SF23
FDD wrote:
02 Mar 2023, 13:55
What would you like pics of?
Re: Ferrari SF23
nico5 wrote:
02 Mar 2023, 13:45
Two very naive questions about that heavily downwashing driveshaft:
I was under the impression that suspension/driveshaft elements were mandated to have a neutral angle, is it not the case?
Is that bit considered far enough from the diffuser exit so that some downwash might actually help drive the rear corner winglets by increasing their AoA rather than inducing separation in the diffuser edge itself, which is most sensitive as it's where you also go for lateral expansion at aggressive radii, although far less than pre-'22. The fact that the trailing edge only dips down towards the outside would point to that. Would the downward transition combined with the relatively high camber of that wing body also help achieving that 45°-outwash effect that they're aiming for in the diffuser corner?
Aerofoils have no camber (neutral), angles don't need to be (except the camera pod angles I think). I think you are right about the driveshaft and brake duct winglets, although there is no lateral expansion in the diffuser at all since last year. Teams use big radii clearance in rules to add some curvature locally, but that's just to speed-up the airflow locally and reduce the pressure just a bit more. Outwashing diffuser would have an entire fence curved outside and this is not the case, rules don't allow that.
Xyz22
Xyz22
123
Re: Ferrari SF23
Re: Ferrari SF23
FDD
FDD
81
Re: Ferrari SF23
02 Mar 2023, 13:55
FDD wrote:
02 Mar 2023, 13:55
Front wing
FDD
FDD
81
Re: Ferrari SF23
That FW in the background looks like one with higher DW than the one they used ov tests.
SoulPancake13
SoulPancake13
Re: Ferrari SF23
Has anyone seen the single pylon rear wing yet? The latest formu1a.uno post says they will bring the new wing but the author also isn't Duchessa. Additionally, could it be possible that Ferrari run much skinnier wings this season because they get much better airflow than last season to the RW?
Re: Ferrari SF23
That's the same as the one in the tests
Shell
Shell
Re: Ferrari SF23
I think they need to test at least 2 BW, one from the tests and another for Bahrain and see which is good enough for both quali and race pace
From my understanding Ferrari in the pre-testing they chose to test for other tracks and let Bahrain test for this weekend FP1-2 and 3
gordonthegun
254
Re: Ferrari SF23
It seems that the floor edge has a rise that was not there in the tests:
SmallSoldier
SmallSoldier
479
Re: Ferrari SF23
New front brake configuration for the SF23:
Vía: Sala Stampa
Xyz22
Xyz22
123
Re: Ferrari SF23
Vanja #66 wrote:
02 Mar 2023, 11:39
Bigger beam wing upper flap than seen in testing. Not as big as last year, so this is something like medium-downforce beam wing :lol: The nuances will be crazy in 2025 the way things are going :lol:
02 Mar 2023, 11:23
Can see a bit of underfloor sculpting here I think.
I think that's still the chassis bottom...
You got it right first as usual Vanja :D
https://www.formu1a.uno/ferrari-tanta-c ... r-la-sf-23
JPBD1990
JPBD1990
49
Re: Ferrari SF23
Anyone manage to wrangle a better pic of the floor and confirm if it is indeed different to testing or not?
