This is something I noticed many times. Front runners are allowed more.RZS10 wrote: ↑20 Jun 2021, 22:41It doesn't matter if he gained an advantage or lost out ... the race director's notes clearly stated that anyone not making the corner would have to go through the bollards, he did not, and it wasn't even that he got pushed out whilst fighting for position, he just did not make the corner - so he should have made that little detour which surely would have cost him further positions (many, probably), he did not do so and only lost one place which kept him in contention for the win.
He did not even bother with pretending to go for the bollards in order to claim that he wouldn't have made it at that angle and speed, just got back on track the fastest way possible.
So Masi's own notes aren't even worth as much as the paper they're (not) printed on ... would the penalty of going through the bollards fit the crime of making a mistake? Probably not, but of course he got away with it.
Obviously Bottas should have gone the long way when he missed corner 4 which would have cost him the position to Checo, but at least Masi was consistent in ignoring his very own rules there.
The one thing you could say is Max was not willing to put Lewis in danger so left ample room on the outside (also so that Lewis could still brake, with Max in front downforce would be gone) so maybe that was a mitigating factor, because that compromised his own entry. Also, the fact that Lewis took an extremely long time to manoeuvre into his starting spot. I am sure they noticed that as well. Causing Max to have colder tires. But yes, he went off under his own steam, If he would have tried the foam boards (literally impossible to reach that late in the corner) he would be like p15 or so.
He got away with it. I thought those foam boards were a tad excessive as punishment. Or was there like a valid place that if you exit the road later on in the corner you could return as Max did.
In 2019 there was a crash and max just merrily went out of the track to rejoin in P2, I think it also likely the foam boards were for that scenario more then when actually trying to make the corner.
