Ferrari SF-24
dialtone
dialtone
121
Ferrari SF-24
jambuka wrote:RB, Mclaren and Mercedes(new floor) both seem to have lot of jagged teeth on the sides. But Ferrari floor seems to be smooth on the side. Any ideas as to why that is ?
Red Bull
Mclaren
Mercedes
Ferrari
May want to read this:
viewtopic.php?t=31078
The summary is that it’s pretty complex and hard to guess what they do without some modelling.
Guesses are that they deal with tire squirt, probably send some vortexes to the diffuser to improve extraction like the mouse hole, as well as re-energize the flow coming from under the floor to improve extraction.
Floor sealing isn’t quite right otherwise you wouldn’t have slots in them and while you do want to prevent dirty air to go under, if you allow the right vortexes under the floor you will improve performance.
Might all be gibberish as my understanding is limited.
ltitus8900
ltitus8900
Re: Ferrari SF-24
dialtone wrote:
17 May 2024, 05:10
Red Bull
https://pbs.twimg.com/media/GNtxYo-XgAIhKMQ?format=jpg
Mclaren
https://pbs.twimg.com/media/GNtsdagWIAA6OpS?format=jpg
Mercedes
https://pbs.twimg.com/media/GNtpnXnXkAAx5OE?format=jpg
Ferrari
https://pbs.twimg.com/media/GNsPnYkWsAArvr2?format=jpg
I think the RB20's front diffusor turning vane exits are further rearward than most to maximize the front downforce load and maintain a more balanced platform. They may also help with porpoising as well. But it is not a one-trick solution. Having it that rearward allows them to create a more efficient solution to keep the tire wake away. As a matter of fact (I think is one of the reasons they are able to maintain a good balance of high and low speed. I might be missing a few things but if I am right, it means less front-wing and rear-wing complexity, lots of air to feed the diffusor, and so on.
I think the new floor is to simply maximize floor extraction but also clean up the flow structures along the side.
Re: Ferrari SF-24
ringo wrote:
17 May 2024, 03:08
The floor edge is very big. The hingers are deep in towards the side pods. Not new but I just noticed how much of the floor is the floor blade.
What they have done now is make this a very independent piece of the floor by adding the goose neck supportat the rear.
The floor edge can ride on the ground and still have enough air gap between it and the main floor to prevent stall. The steel gooseneck hinges if you will can also take a lot of hammering over curbs and not distort the whole floor. Just rhe floor edge will ride the ground or curb and hinge upward or have some compliance; since im sure the supports arent moving hinges (the will allow movement though).
Ferrari seems to design it's edge blade as part of the floor(the old version, dating back to last year, even connected seamlessly to the rest of the floor), while others have as something you glue on to the floor.
Luscion
Luscion
99
Re: Ferrari SF-24
yooogurt
39
Re: Ferrari SF-24
FORZA FERRARI!
Re: Ferrari SF-24
The modification to the FW, now it has a small rise near the adjuster instead of a linear outwash drop.
Goblin42
57
Re: Ferrari SF-24
jambuka wrote:
17 May 2024, 04:22
Red Bull
Mclaren
Mercedes
Ferrari
lmao reminds of that fake 2023 Alfa romeo car reveal we got with a ton of vortex generators on the side
matteosc
matteosc
30
Re: Ferrari SF-24
I do not see any mention to the floor itself. Did I miss it?
falonso81
Re: Ferrari SF-24
matteosc wrote:
17 May 2024, 16:00
I am curious about this too. My understanding was that they were going to introduce a completely new floor.
Re: Ferrari SF-24
yooogurt
39
Re: Ferrari SF-24
Ferrari SF24 with asymmetrical engine cover cooling intakes
FORZA FERRARI!
Xyz22
Xyz22
123
Re: Ferrari SF-24
matteosc wrote:
17 May 2024, 16:00
I think the changes on the floor are "implied" in the diffuser description with "upstream changes".
Re: Ferrari SF-24
I think the description is backwards, old is new, new is old.
There's even the blue wheel cover from Miami.
amr
amr
Re: Ferrari SF-24
Is it me or the front of the halo has been "sharpened" up?
For reference here is a pic from Australia:
jrdls
jrdls
Re: Ferrari SF-24
amr wrote:
17 May 2024, 17:18
https://formu1a.uno/wp-content/uploads/ ... 45-42.webp
https://cdn-1.motorsport.com/images/mgl ... sf-24.webp
If I recall correctly, the halo is supplied by a third party, so it's unlikely something has changed.
