McLaren MCL38
M840TR
M840TR
314
Re: McLaren MCL38
mclaren111 wrote:
05 Jul 2024, 15:27
https://f1tcdn.net/images/news/2024/bri ... laren.jpeg
https://i.ibb.co/cynqnyq/GRu-VOw-Xs-AAMAqr.jpg
The Engine Cover under Chrome looks different...
Yes they removed the cooling louvres
LionsHeart
LionsHeart
Re: McLaren MCL38
M840TR wrote:
05 Jul 2024, 15:32
mclaren111 wrote:
05 Jul 2024, 15:27
And I found changes. Where the Dell inscription is, there is an additional outlet for hot air. The suspension pushrod is attached approximately in the same area.
Venturiation
Venturiation
98
Re: McLaren MCL38
LionsHeart wrote:
05 Jul 2024, 19:05
M840TR wrote:
05 Jul 2024, 15:32
mclaren111 wrote:
05 Jul 2024, 15:27
https://i.ibb.co/3chCBSh/363407-F6-1816 ... -B4-F3.jpg
https://i.ibb.co/0CFF3R2/F7-ADC1-F8-7-D ... -F4-ED.jpg
It looks the same, just different car position on the track
ollandos
ollandos
Re: McLaren MCL38
LionsHeart
LionsHeart
Re: McLaren MCL38
Venturiation wrote:
05 Jul 2024, 19:11
LionsHeart wrote:
05 Jul 2024, 19:05
M840TR wrote:
05 Jul 2024, 15:32
No, there was no additional side exit before.
Early version
Re: McLaren MCL38
Re: McLaren MCL38
The whole engine cover is significantly slimmed down, despite having described it on the documents as just a change in terms of the louvres/outlets :mrgreen:
Rikhart
Rikhart
19
Re: McLaren MCL38
mwillems
40
Re: McLaren MCL38
Some more close ups of the car. Nothing new here but some nice shots anyway. Nice big beam wing at the back, almost a complete extension of the diffuser, it looks quite sizeable.
Do Mclaren run typically bigger beam wings now?
Would explain some of the DRS speed, trading diffuser efficiency for outright top speed.
-Bandit
Re: McLaren MCL38
sjy1969
sjy1969
Re: McLaren MCL38
So, is Norris running an old spec floor or not? Common sense, and the timing sheets yesterday, would suggest not.
Both cars were certainly running the pre-Austria FW in P3.
mwillems
40
Re: McLaren MCL38
sjy1969 wrote:
06 Jul 2024, 14:37
I don't believe they are. Everything was fixed I think.
-Bandit
_cerber1
248
Re: McLaren MCL38
By @F1Techy
According to Franck Montagny , McLaren used a trick consisting of attaching the rear fixings of the floor to the exhaust, in order to exploit the heat emitted by it to expand the carbon and thus improve performance.
let me tell you mainly about this trick, it’s not about expanding, but more about conducting the heat to the diffuser which Lowers the air density and raises viscosity, It will help creating a lower pressure in the diffuser and faster flow across the throat.
Look at the pictures below McLaren actually fixed the clips on the exhaust.
Hoffman900
Hoffman900
208
Re: McLaren MCL38
_cerber1 wrote:
08 Jul 2024, 21:10
By @F1Techy
https://pbs.twimg.com/media/GR8HMxEW0AE ... ame=medium
https://pbs.twimg.com/media/GR8jDMXWoAA ... name=large
That doesn’t make any sense and I’m not buying that theory, at all.
You know F1 cars make less downforce in Mexico, LeMans cars go faster at night, and air can get so hot / lose enough density that aircraft can’t take off, right?
https://www.motorsportmagazine.com/arti ... h-f1-cars/
And this assumes you reduce density from convection evenly through the entire air column (you don’t).
BigBeansBoy
BigBeansBoy
Re: McLaren MCL38
_cerber1 wrote:
08 Jul 2024, 21:10
By @F1Techy
I’m extremely skeptical of this statement. There’s far more surface area on the stay just in the air than touching the diffuser, so if it’s energizing any air it’s the air going through the beam wing. There’s also no way there’s an appreciable amount of energy being transferred to the air. I don’t even think it’s worth doing the math to calculate the negligible amount of energy being transferred to the air.
What I think is more likely is that this is the least intrusive place to put a stay and/or there’s an important synergy of the diffuser and exhaust and having them being an exact and constant distance from each other is helpful
