FittingMechanics wrote: ↑01 Jul 2024, 12:40
mwillems wrote: ↑01 Jul 2024, 12:29
The crash caused by the Squeezing?
As I say, I don't think it is inconsequential outside of the race. Inside of the race, yes. But what is important outside of the race is that the Stewards set a precedent by saying that this sort of driving is unacceptable.
I agree about Max making his own High Speed corner out of a low speed one, but I said that already when replying to Chris in a separate post. It is separate the the incident that this post is about, which was the squeezing and subsequent crash.
I wouldn't call it squeezing as it was done on the brakes and Norris was on the edge of the track. Sure, he could have theoretically moved under braking to let Verstappen have better exit out of corner. You can't squeeze people on the brakes on the edge of the track. Rule against moving under braking exists because you can't and shouldn't squeeze people on brakes.
Squeezing works when you are under power and have room to move. Squeeze someone to the inside so he has to brake much earlier. What Verstappen did was crash into Norris by trying to open up his corner, all of this done under brakes as a reaction to Norris. And this is without mentioning him moving under braking in earlier attacks (one of which could have been a clear Norris hitting Verstappen into the rear).
Unfortunately it is in the Gray area of the rules in the way that he pulled across, that it is hard to say it isn't squeezing. Weaving is normally to block someone, but in this instance he wasn't blocking Lando, just reducing the space he had to get into slowly and aggressively and earlier than you normally would.
The stewards were deliberately vague as they knew anything could become inflammatory, but the document spoke specifically about the action being when Lando was
alongside Max and therefore the penalty is not about moving under breaking, which happened before Lando was alongside.
There is an issue here in that once a driver is alongside you've always been allowed to move back across to squeeze a bit, even if you've already moved once in the braking area. And I don't want that changed. you aren't a danger to someone if you leave space and squeeze. it's hard and fair racing in my view, to squeeze
when the car is alongside. He's done exactly that here, but started the move earlier but without overtly closing the space before Lando was in it. This is why the punishment is only for what happened when Lando was alongside Max. Which is the squeezing.
But what could be dealt with today, in this incident, was dealt with in the right way, in my view, based on what has happened in the past.
I would agree that they need to tighten up the regs about not being able to move twice into a squeeze until the car is alongside though, because the intent is to move Lando into a worse position before he's alongside, which in my view should now also be called blocking but is currently in a very gray area and it's something the FIA need to look at.
