2016 Austrian Grand Prix - Spielberg, Fri 01 – Sun 03 Jul 2016
strad
117
Re: 2016 Austrian Grand Prix - Spielberg, Fri 01 – Sun 03 Jul 2016
AND just why should I have to fiddle around with their program to make it work?
Screw that.
Sir Stirling Moss
Juzh
161
strad wrote:AND just why should I have to fiddle around with their program to make it work?
Screw that.
Well, if you wan't the most information that's pretty much what you have to do.
Or just use the online timings. Those do not crash.
ChrisDanger
ChrisDanger
26
Screw that.
Neither does the app, when used on a native (i.e. Android) device.
markc
I'm confused with all this bluestacks talk in the race thread....? Does all of this belong in here?
Vasconia
Mostly fine conditions are expected for Friday morning on the Red Bull Ring with the risk afternoon, showers and thunderstorms. Away from shower activity, weak winds are expected with a maximum temperature of 25 degrees.
On Saturday, a mostly sunny start with showers and thunderstorms expected to develop during the day with a high chance of the Qualifying being affected. Temperatures are expected to reach a maximum of 24 degrees by early afternoon.
Cloudy conditions are expected on Sunday morning with the chance of some light rain. However, during the day, a mixture of sun and clouds will prevail with dry conditions expected for the race. Weak winds are expected with temperatures reaching 20 to 22 degrees.
http://www.f1-fansite.com/f1-news/formu ... derstorms/
iotar__
Track:
- resurfaced, quicker, two stops probably
- :-( http://www.motorsport.com/f1/news/red-b ... /[quote]Di Resta "There's a lot less compression through the final corner, the profile has changed slightly, so it's a bit more of a normal corner. The kerbs are a bit different as well, so it's little flatter and a bit more forgiving to a point.[/quote]
- At Turns One and Two, 25mm negative kerbs have been installed on the entry, with 55mm high 'sausage kerbs' fitted at the exit to act as a deterrent. Furthermore, 100mm 'Abu Dhabi' kerbs have been fitted behind the apex kerbs at these key turns.
There are also negative kerbs on the entry and exit of Turn Three, as well as the entry to Turns Five and Eight.
At the latter section of the track, negative kerbs have been laid at the exits of Turns Five, Six, Seven, Eight and Nine. http://www.motorsport.com/f1/news/red-b ... nd-793641/
Vasconia
iotar__ wrote:Track:
[/quote]
Is it somekind of a hobby to try to ruin a perfect track?
sosic2121
sosic2121
Vasconia wrote: Is it somekind of a hobby to try to ruin a perfect track?
lol
Hermann did that 20 years ago
basti313
basti313
markc wrote:I'm confused with all this bluestacks talk in the race thread....? Does all of this belong in here?
Well it is a way to see the race...and a good way to see the reality of what happend during the race. So not totally off topic. And definitely better than Fanboy-Ying-Yang, which will start soon again, isn't it?
By the way, I think I missed the usual "Ham will win this" post? :D
Don`t russel the hamster!
SparkyAMG
Probably because a lot of people don't expect him to win this one. Rosberg's been very strong here in the past 2 seasons, has had better starts overall and it's one of the harder places to overtake at.
Maker37
Maker37
Vettel changing gearbox.
5 places penalty.
basti313
basti313
Maker37 wrote:Vettel changing gearbox.
5 places penalty.
Shi*....another boring one.
GoranF1
GoranF1
151
5 places penalty.
source?
ripper
ripper
39
A source I've found:
http://www.f1analisitecnica.com/2016/06 ... ttone.html
Important things:
- VET probably will have to change gearbox and suffer 5 places penalty
- FER is going to use 1 token on MGU-K to improve recharging and deployment
- FER could use a new Shell fuel
- FER is evaluating if they have to change ICE on both cars
- MER will change ICE, TC, MGU-H, MGU-K on both cars without using tokens
- MER will probably use tokens on SPA GP
Vasconia
ripper wrote:A source I've found:
Important things:
Oh, that sucks. I was expecting a very competitive Vettel for this weekend. :(
