Scuderia Ferrari SF71H
Re: Scuderia Ferrari SF71H
MtthsMlw wrote:
09 Apr 2018, 21:10
AFAIK they only changed the central section of the diffuser, making it a bit more squared.
It makes me optimistic to see that the much better pace in Bahrain is mainly due to better set up work. They already seem to understand the car better, of course this could be only due to the track's characteristics.
That small change can be very big change in terms of diffuser performance stability, actually. That, along with better set-up and you have a solid car. It was evident when the car was rolled out that it is a solid concept with changes made in all the right places (a lot of drag reduction and extending the floor for efficient downforce), while continuing with some good solutions from last year.
ripper
ripper
39
outsid3r wrote:
10 Apr 2018, 10:09
Speed_399 wrote:
09 Apr 2018, 22:39
I'm italian but my traslation skills are not very good, anyway the right word instead of "tie" should be rod
'Tirante' is something that pulls... like a pull rod? pulling device/mechanism?
This is a "tirante":
Speed_399
Speed_399
Yes pull means "tirare"
Tirante is something that pulls
f1316
f1316
82
So I suppose it would be logical to guess that the new floor might be better able to support the bodywork in the coke bottle area, eliminating the need for these stay and reducing blockage in the channel that’s aimed towards the diffuser.
DVB
f1316 wrote:
10 Apr 2018, 13:57
Yes, they are looking for more DF at the rear of the car.
Everybody is a Ferrari fan.
Michiba
Michiba
Nice onboard of the front wing showing the flex at speed vs braking from 1:02m
At 1:44, you can also see what happens when the car moves out of the slip stream and increases the load on the wing.
It also seems to be much more stable in clean air compared to when following another car.
https://www.youtube.com/watch?v=kq6bLFs ... r_embedded
zac510
zac510
22
Michiba wrote:
11 Apr 2018, 02:28
Nice observation :)
miguelalvesreis
miguelalvesreis
This is a huge channel!
Kind of twisted, isn't it?Image
Enviado do meu SM-T820 através do Tapatalk
outsid3r
miguelalvesreis wrote:
11 Apr 2018, 17:12
Kind of twisted, isn't it?https://uploads.tapatalk-cdn.com/201804 ... 4405cd.jpg
that's last year's car, it was added here just for reference to the 'tirante' thing :)
ScrewCaptain27
577
The FW flaps were reinforced in Bahrain:
- Serj Tankian
Mr. Fahrenheit
ScrewCaptain27 wrote:
11 Apr 2018, 18:07
Trying to take the camera angle in to account, it looks like they've opened up that slot more. The Australia wing looks like they're almost overlapping but Bahrain has a wider gap.
Mr.G
34
Mr. Fahrenheit wrote:
11 Apr 2018, 18:18
11 Apr 2018, 18:07
No, they have the same gap, but the upper one is now reinforced with metal...
BTW good eye! +1
f300v10
f300v10
185
Via @Graftechweb
Based on the above comparison between the modified diffusor used in Melbourne FP1 and the Bahrain version I must admit they are the same. The different angles of the photos from Bahrain made the center channel appear more rectangular. This image proves otherwise.
China - Thursday
Via @AlbertFabrega
JPBD1990
JPBD1990
49
Either that’s the old floor, or the new one is very similar. Keen to see more pictures.
