Lotus E21 Renault
DAMNINice
37
Re: Lotus E21 Renault
Can anyone tell me why they still run those "ears" (closed air inlets for DRD on the airbox) when they are not even using the DRD??
Why aren't they using a slimmer Airbox Version without it?
It´s just making drag and turbulant air for the rear wing without any advantage. #-o
REal men play with twins!
Maxion
Maxion
DAMNINice wrote:Can anyone tell me why they still run those "ears" (closed air inlets for DRD on the airbox) when they are not even using the DRD??
I think the theory going around is that the "ears" are molded into the chassis and can't be just removed. Why they've gone down this route is a bit odd if they're still unsure if they'll be able to run the DRD or not.
DAMNINice
37
Thanks.. :roll:
I know that they are molded into it.. but even I could cut them off and close the hole with CF in my garage in 5 hours... And I´m not an F1 team!!!
raymondu999
Perhaps the airbox roll structure is in the ears? Those are homologated.
失败者找理由,成功者找方法
munudeges
munudeges
-14
It's poor form of Lotus to be leaving something like that on if it isn't needed.
Isak
Isak
Obviously Lotus have found that the advantages of molding the ears into the roll hoop instead of using interchangeable parts outweight the disadvantages. Interchangeable panels are nothing new. Lotus knew from last year that they would not always use the DRD so hey designed the ears with this in mind.
I believe nothing on a modern F1 car didnt atleast have two different design paths with several different iterations. This was chosen as the best design for a reason. And reasons for choosing something in F1 are generally down to performance or reliability, or more often a mix of both.
My guess is that the weight of the system and hence CoG was that much lower if the ears were molded in that it outweighted the aero penalty.
korzeniow
korzeniow
DAMNINice wrote:
Thanks.. :roll:
You can't modify chassis at will. Unless you conduct new crash tests
February 5, 2013
Australia - Friday FP1 & FP 2 (15.03.2013)
High resolution: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8
Forza
238
F1 Australian GP - Friday FP - 15/3/2013
korzeniow
korzeniow
Forza wrote:F1 Australian GP - Friday FP1 - 15/3/2013
http://i.imgur.com/gw2JzZW.jpg
Is it looks like a nail that was nailed trough this winglet.
It seems it's adjustable because there are three holes for this nail to go into
February 5, 2013
seems like a bit of a quick fix.
Forza
238
F1 Australian GP - Saturday - 16/3/2013
Very different bulkhead from last year. First time I see a steering rack placed inside the monocoque in a new F1.
Everything is hidden inside.
First time you see the internal bodywork of the Lotus inplace:
Looks different from the other teams to me... not as skinny, it's baggy but sleek
