1) So the mechanism mounted to the chassis will change the height of the test modules while the car is on track?
2) What is the design of the two test pods that measure, possibly, air flow? I assume an opening in the front but see no opening in the rear, so flow does not go through the pod. How does it function? Does that stacked double pod design have significance?
Brian
