Effects of wishbones slightly angled front/rearward?
g-force_addict
g-force_addict
By not being perpendicular to the car centerline the wheelbase will vary slightly.
What the effect of this?
I guess some anti squat or anti dive effect can result.
Greg Locock
Greg Locock
237
Re: Effects of wishbones slightly angled front/rearward?
That's about it, if you are referring to the parallelism of the hinge axes in plan view (or side view). You also get some weirdness in your bump steer curve for free. If you just mean that from the side view the outboard points aren't on the half way mark, no that isn't an important effect kinematically.
If you want to look at the effect I recommend wishbone.bas which is available from one of the locost sites.
http://www.locostusa.com/forums/viewtop ... 8&start=90
might be a valid link.
