New Toyota Upgrade...
i70q7m7ghw
i70q7m7ghw
49
There is a guy on the Toyota forum who seems to have additional info on the team and posts regular updates. This was his last one...
Ricardo was very quick at Barcelona testing. He had a new feature on his car. It is more or less mass that is connected to the wheel supports and that is able to move. Renault and McLaren are believed to run similar constructions. For RZ with the system he was 1 sec quicker... It is in fact weight or mass that moves when driving corners and is close to the edge of the regulations. Results were that good that the team wanted to run it even at Silverstone but that is nearly impossible. Engine spec upgrade will be there for for Hockenheim.
What do you think?
NickT
Can you please post a link to the forum :?:
NickT
kilcoo316
kilcoo316
21
Increasing unsprung mass?
I dunno if they'd want to do that. It used to be the holy grail in F1 - minimise the unspring mass.
i70q7m7ghw
i70q7m7ghw
49
zac510
zac510
22
I agree, sounds like it breaks the rules of physics :D Unless it is a simplified layman's explanation.
It could be a mass that moves towards the inside wheel to work it a bit harder.
Scuderia_Russ
Toyota have found a second per lap within the rules. In other news, Scuderia_Russ has won the Lottery. As for unsprung mass... surely this is desired in any wheeled application, not just F1.
"Whether you think you can or can't, either way you are right."
-Henry Ford-
i70q7m7ghw
i70q7m7ghw
49
Can someone find some hi res pics of the McLaren and Renault with the front wheels off so we can try and spot the magic system...
RH1300S
RH1300S
They must be talking about the mass dampers that have come up in a different thread. The damper sits in the nose and reduces the resonance of the wheel bouncing over kerbs etc.
NickT
This sounds very much like movable ballast and I was under the impression that movable ballast is illegal :shock:
NickT
manchild
manchild
I'm also under impression that it is movable ballast but it might not be illegal if they've for example atteched piece of heavy material (not THE ballast) to steering system in a way that it moves right when car is turning right and left when car is turning left (in the front end of the chassis). Power steering could do that easily but I don't get how moving several kilogramms of ballast several centimeters (probably less than 10) can give you 1 second per lap. :?
NickT
I thought of that as well, a sort of reverse steering rack. Just can't see how they would get it past Charley Whiting
NickT
benjabulle
benjabulle
G.Piola drawings were published last week in several magazines about that. It was discovered as the nose of Renault cars seemed to be very heavy to carry and there's a sheet to hide what's inside
manchild
manchild
benjabulle wrote:G.Piola drawings were published last week in several magazines about that. It was discovered as the nose of Renault cars seemed to be very heavy to carry and there's a sheet to hide what's inside
You mean this? - viewtopic.php?t=2814
benjabulle
benjabulle
yes
i70q7m7ghw
i70q7m7ghw
49
So what do you think about the apparent 1 second per lap system Toyota apparently have? A load of crap?
The system on the Renault surely doesn't account for 1 second per lap...
