doopie2you wrote:Well the question is like the title says. May a team add a hole in the bodywork like above the side pod? and then let a tube walk through the bodywork and let it exit somewhere at the back of the car? But the use of it is not to cool the engine?
I´m pretty sure this is allowed ......there is no rule stipulating you cannot have inner flows ..in the car ...as this would have rendered the f-ducting illegal ...
Im sure there is/was activity to explore the possibility use inner flows for purely aero reasons .In LMP racing this has been done for years.
You could suck in areas to reduce pressure buildup or boundary layer by having a tube ending at the very tail of the car ,could you?
