Roll centre height?
Kamaz
Kamaz
Roll centre height?
Hi everyone,
I came across an interesting suspenion geometries variable - roll centre height. I know that by using short length instantaneous centre swing axle Roll Centre can by controlled pretty well with minimum dispalcement. Now the question is how close RC should be in relation to instantaneous centre? Do engineers try to achieve minimal distance between RC and IC on F1? or it is better to leave RC at ground level?
My initial thought is that the closer RC is to IC the less weight transfer occurs resulting in even weight distribution within vehicle? Am I right or nowhere close?
What are pros and cons of keeping RC close to IC?
Thank you for your valuable opinions!
Caito
Caito
Re: Roll centre height?
[Jersey Tom]2 inches above ground.[/Jersey Tom]
I believe most of your questions have already been answered. Use the search function.
There's valuable information in the fsae forum too.
In google, try the following:
site:fsae.com yourquery
Come back 747, we miss you!!
