mwillems wrote: ↑24 Mar 2022, 16:50
CjC wrote: ↑24 Mar 2022, 12:30
mwillems wrote: ↑24 Mar 2022, 11:08
I'm fairly convinced that the new brake solution which no longer ports hot air to the car is a big reason for the step back in performance.
Could this have been some kind of new blown diffuser concept but using the hot air from the brakes?
What has given you the impression they were browning the diffuser with hot air from the brakes? Or is it your own train of thought?
I don’t mean to sound condescending or anything btw I’m just curious
All I can see is air used to be ported back into the car.
The question about whether it can blow came from my imagination. No need to worry about being condescending, your technical and rule knowledge is almost certainly greater than mine.
I doubt any air from the front axle is been used for the diffuser, I’ve been thinking about it and can only point to one issue with the brakes affecting performance:
Warming the front tires: If they were using the heat from the brakes to manage front tires temperatures, changes in the brake ducts could prevent them from achieving optimum tire temperature, therefore losing mechanical grip.
I don’t think the impact of the size of the inlets would have a huge effect on aero, to the point of creating the struggles they are experiencing today and even though the exit of the hot air from the brakes will influence somehow the front tire wake, I can’t imagine that it would be a large impact to create the loss of downforce that the car is experiencing.
