Maybe the ride height is preventing us warming the tyres the way we want, I honestly don't understand it, that's just grabbing at straws.
5th in the constructors?mwillems wrote: ↑17 Nov 2023, 14:44I was expecting the two cars to run with different wings, I'm really surprised they didn't.FittingMechanics wrote: ↑17 Nov 2023, 13:42I bet the team has the other wing as well but they haven't mounted it. It's not a job you do in middle of a FP.
Do we know they brought any other wings? Do they actually have anything else to bolt on?
If they haven't done it now them I don't think they will, FP3 is not the time to be playing with wings, unless they need to fly something out in a very big hurry.
But.... it's a nothing race anyway and don't hate me but I'd be happier finishing 5th
I think that going higher downforce is obvious solution. The car looked very very hard to drive in the slow corners. Lando made multiple mistakes.mwillems wrote: ↑17 Nov 2023, 15:02Looking at the telemtry:
Acceleration up to 250 seems on a par with those around us, we drop back against Ferrari with DRS open because they have the majority of their downforce generated by the DRS flap, so when open they get an advantage.
There is almost nothing we can do to reduce this as we have no wing that can compete here, bolting on downforce won't help.
Against Verstappen it looks like we are running a higher engine mode and they are running a bigger wing. They can catch us with DRS open but we are faster than them on the straights, and they will catch us more when they turn their engine up so that gap will grow, from what I can see.
Time gained on the straight is nothing compared to the time lost on Turns 6-9 and turn 12, where we suffer huge losses.
They did 2 laps in FP1 and then had FP2. They had no data after FP1 to know whether they need another wing. But as you said, if they had doubts they would have split their wings in FP1/FP2.
True, the other M team usually has issues.trinidefender wrote: ↑17 Nov 2023, 12:17Errr, when last did they have any large issues with cooling? Maybe you're thinking of the other team beginning with M.
Pretty much every team has issues running in traffic for extended periods of time
Yeah, there's no glory for me in 4th or 5th, I want the biggest swing as possible at 1stCjC wrote: ↑17 Nov 2023, 15:435th in the constructors?mwillems wrote: ↑17 Nov 2023, 14:44I was expecting the two cars to run with different wings, I'm really surprised they didn't.FittingMechanics wrote: ↑17 Nov 2023, 13:42
If the wing is a big part of that, then having an old wing here (22 Wing) will prevent that I guess.
It won't do any harm. But this looks to be something different than just a DF problem. In Austin you could see the car was struggling with grip and it was in places DF loss from ride height and the affect of some bumps to which wing would have helped. This looks a totally different problem, we look slow everywhere and it is why I can only guess they are having a problem with the tyres as a result of the setup they seem to need to take.FittingMechanics wrote: ↑17 Nov 2023, 16:38I think that going higher downforce is obvious solution. The car looked very very hard to drive in the slow corners. Lando made multiple mistakes.mwillems wrote: ↑17 Nov 2023, 15:02Looking at the telemtry:
We will see what happens in FP3.
Porpoising/ride height probably meant they have to ride higher and then the car does not produce enough downforce for the corners.
I'd seen those comments about a lower PU mode in the comments. Doesn't look like a lower PU mode to me.Dafnalina wrote: ↑17 Nov 2023, 18:38
We might be running a lower PU mode, but sill the car is too draggy.
The easiest solution would be higher df, but I feat they've only brought this attempt at a rb wing, only for rb to run a higher df wing here lol.
Hope they can find more performance, Lando being so far off the pace in the long runs is worrisome
mwillems wrote: ↑17 Nov 2023, 18:46I'd seen those comments about a lower PU mode in the comments. Doesn't look like a lower PU mode to me.Dafnalina wrote: ↑17 Nov 2023, 18:38
We drop back when DRS opens, the rest of the straight we are one of the fastest, second only to Alonso, so I dispute the idea that we are draggy until DRS is open where we don't get the gains others do.
The speeds below are just when the DRS is open, before that we are only slower than Alonso, then you can see the dip in top speed.
https://i.ibb.co/Zgk7r5N/Vegas-FP2v2.pn ... egas-FP2v2
organic wrote: ↑17 Nov 2023, 16:15Rpm of Merc is also high. See compared to McLaren..AR3-GP wrote: ↑17 Nov 2023, 16:13Hamilton had perfect tows on both straights on his fastest lap so I think the straight line speed is deceiving for that lap in specific.
https://i.postimg.cc/RhBF632p/image.png
