2024 Austrian Grand Prix - Spielberg, June 28 - 30
dialtone
dialtone
121
Re: 2024 Austrian Grand Prix - Spielberg, June 28 - 30
deadhead wrote:Image
That’s surely a dangerous way to determine track limits but it sure will work, just need to keep his hand up for the duration of the gp, if the hand ever falls then someone went over the track limit. Easy sensor.
They just painted the previous white line limit black, painted some of the kerb black too widening the track in that area & then stuck gravel on the far side.
Why didn’t they just stick to the old white line limit?
214270 wrote:
27 Jun 2024, 22:22
They just painted the old track limit black, painted some of the kerb black too widening the track in that area & then stuck a gravel on the far side.
Why didn’t they just stick to the previous white line limit?
I believe this is just a temporary solution to test if this strip of gravel idea is valid before they commit to it
Farnborough
Farnborough
103
:D
dialtone wrote:
27 Jun 2024, 18:36
"Toto was determined to stop his drivers damaging their floor in Austria again"
214270 wrote:
27 Jun 2024, 22:22
The track isn't wider. The gravel is in the same place. You couldn't driver "wider" even if there were no markings at all. What's likely being done is color contrast to aid with the AI-vision monitoring that they are deploying this weekend.
A lion must kill its prey.
Seerix
Seerix
It's because the car could be all wheels behind the white line, on the kerb, but it would not reach the gravel trap. That would not help preventing the track limits.
So they needed to make the track wider and the white line further out on the kerb, hence they painted it that way.
They probably could not put the new gravel closer to the original white line (bcz MotoGP and what have you).
And yes, the white line moved outwards, so the track is by definition wider, isn't it? If you go behind the white line, your laptime will be deleted as usual, but you will also lose time as you'd run through gravel.
Seerix wrote:
27 Jun 2024, 22:48
Yes i suppose, the start of the gravel trap could’ve been adjusted inwards though. I guess this is a solution that also works
27 Jun 2024, 22:24
214270 wrote:
27 Jun 2024, 22:22
When you say temporary, are they planning on making adjustments through the wkend? That’s quite tough given it’s a sprint & little time for the drivers to adapt, session to session.
214270 wrote:
27 Jun 2024, 23:01
27 Jun 2024, 22:24
214270 wrote:
27 Jun 2024, 22:22
I meant for this year
Alexf1
Alexf1
214270 wrote:
27 Jun 2024, 22:22
Cause then the curb would be 2m wide just like the car, now curb has been brought back to 1,5m wide so inside wheel is always within the white line unless you put the outside wheel onto the gravel.
FittingMechanics
FittingMechanics
16
214270 wrote:
27 Jun 2024, 22:22
The explanation given was that they wanted for all cars this weekend (including junior categories) to be wider than the distance from the white line to the gravel. So that they don't have to police it.
Good idea.
FittingMechanics wrote:
28 Jun 2024, 11:55
214270 wrote:
27 Jun 2024, 22:22
Good idea.
That makes the most sense; all formula cars this wkend get gravel if they exceed the limit.
It’s still quite a weird thing to adjust to I suspect, the track limit line is totally irrelevant for F1. Pilots have to sight the far side/gravel edge for their track limit guidance.
Nice to see them here! =D>
Luscion
Luscion
Any indication that Merc are running a higher engine mode than the rest? they seem oddly quicker than the others
