Weird take. You agree with the penalty for Norris because he should expect Max to approach the corner with a ”you back off or we crash” mindset?PlatinumZealot wrote: ↑21 Oct 2024, 13:49Everbody quiet! My time to talk!![]()
I agree with the ruling for Norris going off the track. It's yet another example of unpolished racecraft from Norris, not quite a champion driver yet. He's looks to be still on the learning curve. What he did, is a common move that Max used to do in the past, which is not trying to brake later than the defender to the Apex, only just sided by side and then running wide to overtake on the outside of the track. I was never phased by the ruling because it was a slam dunk.
You literally cannot attack Max from the outside of a curve entry. It will fall. He's knows all too well to let his car run "off the brakes" to crowd your apex and run you off the road. You have to attack him from inside or even better yet on the straight.
I'm just ever more convinced now that Lando is the quickest driver but not that great at wheel to wheel.
Anyone should be able to attack anyone on the outside if they are far enough ahead when braking for the corner, and be given room all the way through the corner, including the exit. That has always been the case in racing and never been a problem until Verstappen came and did these moves, and the governing body deciding to let it slide for ”the show”. It’s a farce. It requires no skill to do that, and it’s simply bizarre that they don’t change this rule, because you know there will never be any fight when someone is racing Max, it will just end like this all the time, with a controversy after every single race instead of looking back at a great fight. We will be here after Mexico as well discussing the same thing if Lando is chasing down Max with a pace advantage. We will be here discussing the same thing in Brazil as well. That is not how a sport should be enjoyed.
What should have been done for Norris though, was to slap a five or ten second penalty for doing an extremely late moving under braking in turn one, just to set an example of how to conduct yourself on track. And in the end sometime down the road, we might be done with these subpar racing moves once and for all.
