oh my god Lewis is charging!!
C'mon BOB!!
Timo spins out, hitting jarno Trulli. Looked like a rear brake lock-up.
Edit:
Petrov runs wide on the last corner, Lewis overtakes and has the run down the straight. Petrov then attacks down the inside into corner 1, loses position! Now Petrov is going off into the distance, a bit. might turn out to be a good battle. Renault had the speed too.
I have no live timing. No money on my phone to use the mobile application (not the iPhail app).
Exactly the same again from Vitaly and Lewis. Lewis then weaves all over the track and he will have to be penalised for it. As it's more than one defensive line. I suspect it'll be a long time before he gets the drive-thruough.
Minus that, they were racing well.
Button now passed Alonso. Button to take on Massa. Massa is still behind Buemi.
Kobayashi is now out. Stuck in-gear. Bad race for the Sauber lads.
Edit: Lewis has got away without penalisation. Just warning.
Schumacher out, mechanical failure. Couldn't hear what (was at a gig last night so I've only got ringing in my ears haha)
Liuzzi is seamingly out too.
