Moanlower wrote:You're just reading it as you would've liked it to be and holding on to it hoping it will stick.
No, I'm reading exactly what it says I'm afraid.
Ofcourse the race wasn't ended yet and thats not what the rule says.
Yes it does:
If the race ends whilst the safety car is deployed............"
It makes no assumptions whatsoever and it is clearly overridden there if the safety car is not deployed, because that's what it depends on.
How on earth could they mean if the race was ended following with 'the SC will enter the pit lane at the end of the last lap.
This is a mistake you and others keep making. That is neither here nor there I'm afraid, and it doesn't even matter if the rule is logically nonsense. You look at what the rule says, apply it and then come up with something better if it doesn't do what you intended. That's why Formula One's governance is such utter shite.
I mean, why bother having rules and wording them at all?
Anywho, enough said. You just don't want to see it.
There is nothing else to see. The wording of whatever this ruling actually means is clear. I'm afraid you're desperately not looking at the actual wording of the ruling and you've never done so in any of your posts.
