Who said they didn't experience the same force? Yes, the Ferrari was lucky to take the impact on a stronger bit than the bit on the Williams. Hence the Williams acted as the crumple zone. Really, it's not that difficult to understand...mep wrote:hahahThe impact ripped Ruben's front wheel off. In effect the Williams acted as the crumple zone for both cars. Ruben's nose went in to the gap between the Ferrari's rear tyre and side pod, the front wing hit Alonso's rear wheel just before the front tyre did. No doubt that Alonso was lucky not to be taken out there and then.
both cars got loaded with exactly the same force.
actio = reactio
The Ferrari was simply stronger (on the loaded point) than the Williams, thats why it didn't break.
Still surprising.
good spot !!!siskue2005 wrote:look at Massa !!!
http://www.youtube.com/watch?v=9kChqJVjp9U
The important thing though is where that force was applied and how much was absorbed by the car and how much was transmitted on or dissipated. In Rubens case, as with Vettel and Button, the car absorbed the impact. In Alonso's case most of the energy was dissipated by the car spinning, lessening the loads on his own car. It was still very surprising how little damage occured, but it wasn't because his car was soooo much stronger than the others.
You can't say this. The suspension should be quite stiff in this car lenghtwise direction because of the high braking forces.Just_a_fan wrote: @mep
The Williams broke because it took the force in a weak direction, the Ferrari in a strong direction.
No, exactly here you miss the point.Just_a_fan wrote: If the Ferrari moving saved it from damage then, by your own assertion that both received the same force, then the movement would have saved the Williams too.
