I don't believe the rule says anything about being half way past. It's illegal to force another car off the track, simple as that.flynfrog wrote:I believe you also have to be half way past the car for them to have to give you room. I don't mind the racing but I don't feel bad Hammy hit the wall either he took a move he had no chance of making unless Jensson let him bymyurr wrote:Only if the other driver intends to run you off the road (which is against the rules). Presumably you don't like it when racing drivers... race?flynfrog wrote:he should have lifted long before that point there was no way he was ever going to make that pass
You believe wrong. There is no delineation in the rules, only that you must not force the other car off the road.flynfrog wrote:I believe you also have to be half way past the car for them to have to give you room. I don't mind the racing but I don't feel bad Hammy hit the wall either he took a move he had no chance of making unless Jensson let him bymyurr wrote:Only if the other driver intends to run you off the road (which is against the rules). Presumably you don't like it when racing drivers... race?flynfrog wrote:he should have lifted long before that point there was no way he was ever going to make that pass
Yep, US GP in 2004. Aguri Suzuki was 3rd in Japan 91.Ciro Pabón wrote:Kobayashi in second place is a record for Japan, isn't it? Sato was third once.
This you can barely call a finish though lolandrew wrote:Yep, US GP in 2004. Aguri Suzuki was 3rd in Japan 91.Ciro Pabón wrote:Kobayashi in second place is a record for Japan, isn't it? Sato was third once.
I think you are right, 2nd will be the best finish by a Japanese driver.
then maybe he should have taken a different line to start with.myurr wrote:By that point it was too late and he probably would have lost control if he'd lifted. He was already having to countersteer due to his wheel being on the grass.flynfrog wrote:listen to the audio he was still in the throttle at that point keep beating that drum
Only if you can't say the letter R.Sawtooth-spike wrote:Is that even a word
show me where it says that in the regs.flynfrog wrote:I believe you also have to be half way past the car for them to have to give you room. I don't mind the racing but I don't feel bad Hammy hit the wall either he took a move he had no chance of making unless Jensson let him bymyurr wrote:Only if the other driver intends to run you off the road (which is against the rules). Presumably you don't like it when racing drivers... race?flynfrog wrote:he should have lifted long before that point there was no way he was ever going to make that pass
Still a result after a race has been finished. The method of finishing the race doesn't matter in the record books.wesley123 wrote:This you can barely call a finish though lolandrew wrote:Yep, US GP in 2004. Aguri Suzuki was 3rd in Japan 91.Ciro Pabón wrote:Kobayashi in second place is a record for Japan, isn't it? Sato was third once.
just give up. Button was staring on Hamilton in the mirror.flynfrog wrote:then maybe he should have taken a different line to start with.myurr wrote:By that point it was too late and he probably would have lost control if he'd lifted. He was already having to countersteer due to his wheel being on the grass.flynfrog wrote:listen to the audio he was still in the throttle at that point keep beating that drum
hell im pretty sure I would not have seen a Truck at that point in my street car with big mirrors Button had no idea he was there.
rain, visiblity, track width, racing lineringo wrote:
what's the difference ?
You believe wrong. There is no delineation in the rules, only that you must not force the other car off the road.myurr wrote:[]I believe you also have to be half way past the car for them to have to give you room. I don't mind the racing but I don't feel bad Hammy hit the wall either he took a move he had no chance of making unless Jensson let him bymyurr wrote:Only if the other driver intends to run you off the road (which is against the rules). Presumably you don't like it when racing drivers... race?flynfrog wrote:he should have lifted long before that point there was no way he was ever going to make that pass
