Late, but:Giblet wrote:The BBC guys said something about wet tires and no DRS. But that was confusing as well, as if you change to inters first, are you the only one on track who can use DRS? Or does everyone have to be off wets.andrew wrote:Not sure Giblet. I thought it was more to do with it being too wet to safely use DRS.
This is why people say the rule is not straight forward. When less than straight forward conditions come into to play evne hardcore fans like us get confused.
First: If starting behind the SC because of wheather conditions anyone must use heavy wets.
Second: DRS was disabled because of wheather conditions.
BUT: There are no associations in the regs, but in common sense.
