Ferrari F2012
enz0
enz0
Re: Ferrari F2012
I don't know how to asses this guys, are ferrari's parts working really well?
Forza
238
Re: Ferrari F2012
FP1
aleks_ader
90
Re: Ferrari F2012
thisisatest wrote:i believe those holes circled are holes to access the mounting screws or nuts. they fasten vertically to the beam wing and to the floor. the car has these on other parts, such as the turning vanes by the radiator intakes.
(pic borrowed from the previous page)
[img]http://www.formula1.com/wi/sutton/2012/ ... 98.jpg[img]
1+ =D>
Here even confirmation from scarbs...
@alogoc: @ScarbsF1 wrote:they are the holes for the nuts to bolt the wing to the floor, they're usually covered with tape
jonaliew
jonaliew
Re: Ferrari F2012
enz0 wrote:I don't know how to asses this guys, are ferrari's parts working really well?
With alonso's last run at FP1, if he had made it before the flag came out. Assuming all the conditions were the same (I emphasize assuming) I would say we prolly 2 to 3 tenths behind vettel. Hard to say because we don't know whether vettel was on a flying lap with new tires, low fuel, etc. I know Newey was adjusting a lot of the front wing.
I know with the last 8 minutes where they used the new FW + RW. There was a comment where his RW seemed a bit lose? Not sure what that means. Anyone heard the same?
But 4/10s is encouraging compared to the usual 6/10s behind. I might be wrong again. We will not know until FP2/3 or qualy I suppose.
shelly
shelly
136
Re: Ferrari F2012
In the 4th picture in Forza's sequence, what is the white part before the rear wheel?
twitter: @armchair_aero
Forza
238
Re: Ferrari F2012
It's some kind of thermal pad/heat shielding surface.
More pics from Fp1
Kiril Varbanov
147
Re: Ferrari F2012
Forza wrote:It's some kind of thermal pad/heat shielding surface.
Indeed, this is heat shield, as the hot gases from the exhaust drop down there, pushed by the downwash flow generated from the sidepod form.
Thanks for posting all those "debug" pictures, Forza.
Chaps, correct me if I'm wrong, but the slot gap between the Gurney Flap (wickerbill) and diffuser's upper trailing edge has increased a bit?
Forza
238
Re: Ferrari F2012
Kiril Varbanov@ The Gurney Flap is mounted on small pillars on top of diffuser so they most likely change the angle and position of it according to overall car setup.
Dream Theater
21
Re: Ferrari F2012
Seems really an interesting solution! What do you guys think about that?
Ra8
Ra8
Re: Ferrari F2012
Dream Theater wrote:[img]http://img22.imageshack.us/img22/2015/f ... rmel1g.jpg[/img]
Seems really an interesting solution! What you guys think about that?
Been there already. Its just a measuring sensor.
scarbs
scarbs
393
Re: Ferrari F2012
Dream Theater wrote:http://img22.imageshack.us/img22/2015/f ... rmel1g.jpg
That dipped section under the rear crash structure is new
Reason: Removed quoted pic, above
Dream Theater
21
Re: Ferrari F2012
I meant the hole in the diffuser, under the rear crash structure. I've never seen it before the Indian Gp.
shelly
shelly
136
Re: Ferrari F2012
I think it refers to the gurney bridge
Forza
238
Re: Ferrari F2012
Few more from FP
And F2012 gearbox
enz0
enz0
Re: Ferrari F2012
Interesting Diffuser pic,sorta reminds me of the Double Deck Diffusers back then.
