That indeed could have occurred WB - unlikely, but yes, it could have happened that way. As for Merc not gaining an advantage - even if Pirelli ran everything behind a firewall - Merc still still de-briefed the drivers, still got the car back and pulled it down to inspect engines, gearboxes, suspension etc, engineers would have viewed worn components - so there's absolutely no way, at all, that Merc did not gain some data out of this.WhiteBlue wrote:It is quite possible that the necessary people have trained Pirelli personnel in the use of the Mercedes equipment and did not attend the test. Later Pirelli handed the equipment back to Mercedes - after erasing all data storage - for removal of the equipment from the test location. It would be an unusual procedure but nothing about this test was done as usual. They must have made some very concerned considerations before they went ahead with it. Again I'm not saying it was done that way. I simply point out how it could have been done.turbof1 wrote:Well, to be honest: it would be a fair assumption that they were. The car had to be packed anyway after the test. So even if Mercedes dis not got any view on the data, they would have been around.
But of course, that's a secondary consideration - did they break the rules? Regardless of any advantage, that's not what is in question here. There is no regulation (that I can see) that says "teams can't get an advantage". Even Ferrari would have got advantageous data - albeit from a 2011 car, which they could have transcribed across to 2013 car behaviours in some form of accuracy. How effective it would be, who knows, but they could have done it.
This is actually a big first test for the Tribunal. If they have no teeth, then there's an opportunity to test them again by breaking regs and seeing how it pans out - both for teams and suppliers. If they flick it back to the FIA, the FIA is going to look pretty stupid really. The management of F1 is under a lot of focus at the moment - as it should be.
