Seems we are in the same county, some 8 -9 kN for each tire, braking or accelerating, most interesting indeed.Tim.Wright wrote: ...
For braking I'd guess 5G with 1G coming from aero and 4G coming from the brakes. That gives
4G x 9.81m/ss x 620kg x 65% fr brake bias = 15.8kN for the total front axle
4G x 9.81m/ss x 620kg x 35% rr brake bias = 8.5kN for the total rear axle
I haven't really paid much attention to how much longitudinal acceleration the use in acceleration but the calcs will be the same...
You're wrong. The tires used from the Hungarian GP forward will use 2012 construction and 2013 compounds.turbof1 wrote:-At Germany they will run 2013 rear tyres with the 2012 kevlar belt. The front tyres remain the same.
-At Hungary, they will effectively run 2012 tyres, front and rear. So from that race on, nothing from the 2013 tyres will be taken over.
That means, from Hungary on:
-softer sidewall
-harder compounds
-kevlar belt instead of steel belt
It could very well be that plans are still going to change. Pirelli will test several solutions at the YDT. So we'll have to wait and see, but for now this how it will go.
So its the teams fault! Pirelli are so predictable. Pity their tyres are not.Cam wrote:Get ready for another Hembrey excuse.bhallg2k wrote: This is rank incompetence.
Following investigations into the causes of the British Grand Prix blow-outs, Pirelli believes a combination of teams swapping left and right hand side tyres, plus running pressures too low with aggressive camber choices, caused the incidents.
Michelin in 2005. And by the chances of a miracle they had the exact same problem. Their side walls were more flexible, had a steel band and failed under high speed induced loads.Jersey Tom wrote:When was the last time a tire supplier in F1 had this many problems on multiple race weekends in a season?
Sommerfield also looks at the implications for this years championships and the development resources. The conclusion can only be that the teams with the deepest pockets and the greatest resources will fight it out at the sharp end of the grid. In my view those will be Red Bull, Ferrari and Mercedes. Lotus and McLaren are already out of both championships as a result of their weak financial situation or from a 2013 early performance point of view.Matt Sommerfield @ Pitpass wrote:The root cause of a delamination is damage or cuts to the tyre (usually from
debris) causing a loss of pressure, which in turn increases the heat, peeling away
the tread platform from the rest of the tyre. For Silverstone Pirelli had made
changes to the way the tread was bonded to its tyres. ...
From a personal perspective I see no problem with the way tyres had previously
delaminated in Malaysia, Bahrain and Spain as it allowed (in most cases) for the
driver to either park their car in a place of safety or return to the pits for another
set. The problem with adjusting the way in which the tread is bonded to the
carcass is that it opens the door for the damage to rupture the tyre at its next
weakest point: the sidewall's shoulder joint, which is what I believe we saw at
Silverstone. With the tread platform now more firmly affixed to the carcass when
a tyre deflated (due to a cut) the tread stayed attached, raising the temperature
internally, causing the tyre to let go at the tyre’s shoulder....
On safety grounds the tyres will now revert to the Kevlar banding prototype tyres
issued to the teams during the Montreal and Silverstone weekends. ...
A change in the tyres construction mid-way through the season like we are going
to see will result in the Championship almost being reset. Depending on how wide
sweeping the changes are they could have implications not only in terms of
mechanical grip and aerodynamics but also the degradation level of the tyres
throughout races. This year’s construction was aimed at increasing the thermal
degradation of the tyres whereas 2012's construction was more wear aligned.
It's currently being touted as just a change to the 2012 construction for Hungary
onward but even with the teams having experience with those tyres their current
cars won't be catered towards them. Wholesale changes will have a massive
impact on the direction in which the teams have already taken and continued
development of their cars for 2013, with those reacting the quickest standing the
best chance of winning either Championship. But at what cost?
2014, as we know, brings with it a new set of regulations that demand the teams
focus ahead of their usual design curve. A continued push for development this
late on in the season is not only going to be expensive but may be at the sacrifice
of 2014.
It may yet bite them in the arse. The teams were swapping them around exactly to get more life out of them. By disallowing that, they may inadvertently (or even advertantly) be digging their own grave re early tyre failures.JimClarkFan wrote:I see Pirelli have now blamed the F1 teams for the blowouts... If they had of highlighted the furor caused by the other teams over the tyre test I would have got on board. But instead they are blaming camber, pressure and the way teams are putting the tyres on. It is getting a bit ridiculous now.
