tpe wrote:Can someone post a close-up picture from the start, just to check if tyres are on the correct side of the car?
I can't find anything giving a good picture of the rear tyres, but there's a goldmine on the fronts.
In parc ferme after quali, Hamilton has the the front tyres the right way round - if you zoom in you can see the 'L' on the outside of his left front.
http://www.formula1.com/wi/gi/Lm-S/sutt ... 9ju706.jpg
In the race, this photo (and others) show the tyres have remained on the same side from quali - the arrow for rotation is pointing the same direction. So the front tyres are the correct way round, at least for the first stint in the race. The rears have also remained the same way round between quali and the race, but it's tricky to say which way round they are.
http://www.hirado.hu/Formula1/Hirek/201 ... 1.jpg.ashx
However, on the way to the grid (on an old set of tyres - note the 'R
6' instead of 'L
2' written on them), he has the tyres the wrong way round (see the 'L' on the right). Interestingly, these tyres have the 'official' left marked as the 'Mercedes' right, whereas the quali tyres were matched correctly, having the 'official' left as the 'Mercedes' left.
http://www.formula1.com/wi/enlarge/0x0/ ... br1115.jpg
http://www.formula1.com/wi/enlarge/0x0/ ... br1051.jpg
And in practice, on the hard compounds, Rosberg had the front tyres swapped:
http://www.formula1.com/wi/enlarge/0x0/ ... 9ju519.jpg
Huntresa's post also shows the hard compound tyres being swapped at the front. It would seem then that the 'default' position is to have the tyres swapped, but for peak grip and speed - e.g. qualifying - they aren't. In turn, we can conclude that greater speed is found with the front tyres the right way round, but greater endurance if they are swapped.
"A wise man speaks because he has something to say; a fool speaks because he has to say something."
