Uhhh, I'm missing something, he hit the apex of 3 perfectly...Juzh wrote:3 is not enough for you?beelsebob wrote: Which corners are you referring to other than the ones I mentioned?
Nope...He also slightly missed entry to the chicken.
He actually if anything hit it margionally too hard – he got a bit of wheel spin because of it.
Actually, Vettel takes a very similar line through 5 (slightly tighter), and an identical line through the final turn. By the way, he missed the apex of turn 2 by a foot on that lap.And going wide troughout those corners does not get you better traction or lap time. If it did, everyone would be taking that line but they don't. Nor does Vettel on his lap record from 2010.
Well no ---, that would be because the RedBull is set up for higher downforce and drag than the Merc, hence him losing something like 5 tenths in the first sectorWhat I'd like to see is Vettel's 2nd sector from his first fyling lap which was something like 5thns faster than hamilton's.
