raymondu999 wrote:SectorOne wrote:Interesting, Pirelli saying the tires is not the cause for Mercedes win.
"[It's] something they have done," said Hembery.
http://www.autosport.com/news/report.php/id/109211
Not sure i´d agree with that, it seems these tires are less sensitive to thermal deg, which was the Merc´s achilles heel.
But i´m no tire expert so maybe they do have found something. Maybe it´s the rubber strip we all talked about pages ago.
IMO it's still because of the Pirelli test, but not from Mercedes' side. Rather, on the Pirelli side. And no, I'm not suggesting a conspiracy.
When Pirelli tested the Hungary 2013 hybrid tyres on the Merc chassis, it could've seen, "oh whoops. These rears overheat too easily. Let's make the rears a bit more overheat-resilient."
Because the Pirelli test exposed the weaknesses of the W04+Pirelli combo, those weaknesses were the ones to be sorted out, ie - the design of the tyres has come to the design of the car. Much in the way teams have previously suggested that Pirelli designed their tyres around the 2010 Renault's suspension geometry and gave now-Lotus their everlast tyre abilities.
I thought the issue was over safety? Many teams had exploding tires, even FI that has/had good relative use of its tires. The Mercedes just overheated its tires faster than the rest. Mercedes figured out how to make the tires not overheat, but in doing so started to blow them up, just like several other cars did.
The way I see it, there are two issues here. Tire temperature range/degredation and tire construction/failure. While they are somewhat linked, they are certainly separate issues.
Don't forget that Mercedes has changed their rear suspension several times this year. Also, Lotus was still great in the race with the new tires as was Red Bull. Perhaps it has little to do with the tires and more to do with something Mercedes has done? Exactly what Perelli stated.
