zioture wrote:Look here nolder small vent on the central
What?
Do you mean they have some kind of gurney attached to the hot air exits? If yes, then well spotted, haven't realized it's there up until now...
YesRZS10 wrote:zioture wrote:Look here nolder small vent on the central
What?
I post for you old versionRZS10 wrote:zioture wrote:Look here nolder small vent on the central
What?
I thought cars had to have a starter motor this year?Holm86 wrote:As far as I can see the McLaren doesnt feature at starter hole either.
With the weight penalty, I doubt it. I guess it's possible they are using the ERS motor to start the engine?Gridlock wrote:Maybe they fitted a starter motor - plenty of juice on board
Edit - sorry thought you said SMH above..
The MGU-K is plenty powerful enough to start the engine. So thats what I thought as well.Diesel wrote:With the weight penalty, I doubt it. I guess it's possible they are using the ERS motor to start the engine?Gridlock wrote:Maybe they fitted a starter motor - plenty of juice on board
Already mentioned here - http://www.f1technical.net/forum/viewto ... 61#p486761zioture wrote:Look here nolder small vent on the central
Old version
http://www.newsf1.it/wp-content/uploads ... em_old.jpg
https://pbs.twimg.com/media/Bg1Xgs-CYAAtFWY.jpg
https://twitter.com/ScarbsF1/status/436111349660147713turbof1 wrote:I don't think they'll miss out on the start motor hole; it's an obvious aero benefit.
ah, yeah ...Mr.G wrote:Already mentioned here - http://www.f1technical.net/forum/viewto ... 61#p486761zioture wrote:Look here nolder small vent on the central
Old version
It looks like the body work is bend up on the edge...
It is the same picture I posted Omincorse have canceled the red arrows, you can see something of red in picmclaren_mircea wrote:A technical explanation of the nolders at the back of the mp4-29, altough is in italian.
http://www.omnicorse.it/magazine/34840/ ... arua-calda
La McLaren ha montato due nolder sulle estremità degli sfoghi d'aria calda in coda alla MP4-29: i tecnici diretti da Tim Goss hanno iniziato a introdurre piccoli sviluppi sulla macchina di Woking che sta macinando chilometri con il debuttante Kevin Magnussen.
Il giovane danese ha già coperto 43 tornate nella mattinata, alternandosi al comando della lista dei tempi. Nell'immagine si possono notare le due labbra aggiuntive che servono a deviare i flussi che lambiscono la carrozzeria lungo i vistosi sfoghi d'aria. Trattandosi di Sakhir di una pista che richiede un buon carico aerodinamico, questo esperimento serve a verificare se si può incrementare la forza verticale senza penalizzare troppo l'efficienza della macchina che ha già le "tapparelle" della sospensione posteriore a creare una sorta di "muro" aerodinamico che varia a seconda degli scuotimenti dei bracci (quello inferiore e quello di incidenza).
