Williams FW37 Mercedes Speculation Thread
WaikeCU
Re: Williams FW37 Mercedes Speculation Thread
No Senna logo anymore?
timbo
timbo
113
So the lower wishbone on the front is standard A-arm?
timbo wrote:So the lower wishbone on the front is standard A-arm?
Not completely standard, the front one appears much thicker (copying Mercedes in a way).
rjsa
rjsa
51
WaikeCU wrote:No Senna logo anymore?
Renders, missing merc too, might be just a mistake
roadie
39
Here's the front view in high res. Open in a new tab for the large image.
AfroDude41
AfroDude41
The front wing looks to have barely changed. The trailing edge of the endplate looks a bit different, but that could just be all the black playing illusions. The trailing edge of the uppermost element is the same as the one they started the season with.
Basically they rendered it with a 2014 wing. If that means that they'll continue with that one or just needed to have something in place for the time being, is a different question.
roadie
39
The FW36's front wing barely changed all season. I would be surprised to see a radical new design.
dren
227
It looks like the same car with a Mercedes W05 nose plus a nub added to it. I don't expect to see anything new on these preredered images. The rear of the car is likely where the biggest changes will be, and those will probably be in small details, not radical changes.
Honda!
dmjunqueira
21
IMHO the air intakes on the sidepods look smaller (at least comparing with launch spec 2014 car).
The nose resembles a "mix" of last year's Mercedes and Mclaren...And albeit it isn't a beauty, we have seen worst.
Credit goes to newsf1.it:
dren
227
FW36
FW37
The sidepod inlets have certainly shrunk. Scarbs hinted at potentially larger inlets for more PU cooling due to higher output. It doesn't look that way with the Williams.
Honda!
Probably due advancement in radiator technology. They make steps ever year in efficiency there, making a mechanical part just as important for aerodynamics as aerodynamics itself is.
(Currently working on the front wing article of the FW36. For now I'll assume the wing will still stay the same for next year.
Kiril Varbanov
147
The aspect ratio and scale of the images that made the comparison is different, so I'd take any visual changes with a grain of salt.
Polemik
Polemik
Williams FW37 versus Williams FW36 images :
http://www.motorsport-total.com/f1/foto ... fw37vsfw36
:wink:
